How to set up Aqara Switch Module T1 in ZHA and Skyconnect?
Hi, I want to install a Aqara Switch Module T1 (with Neutral) to Home Assistant with ZHA and Skyconnect. I was able to connect it, but it only shows a wrong device temperature. I don’t see any events and I’m not able to switch the light on or off.
In dev tools/states is also only Identify and device temperature
I found some similar posts, but no solution, except migrating to Z2M, which I want to avoid if possible.
Is there any way to set up the T1 in ZHA with Skyconnect?
I connected the Aqara to deConz and Conbee II. Now I can switch the relais on and off and I get events from one input. But if I press the button the Aqara itself switches the relais
So I assume that I have to configure the Aqara to activate both inputs and disconnect the input from the relais.
Can I do this without an Aqara hub and the Aqara app?
