How to set up scrape sensor
Hi all, just recently managed to get home assistant set up - it’s a really impressive piece of kit. Unfortunately I have poor IT skills and have to use a lot of trial and error to get the system working the way I like, getting there now though and have a few automations set up and working.
I have a hive heating system, but unfortunately this does not have a sensor on the hot water cylinder, control is on/off only. I do have a resol solar controller, and I am hoping to use the sensor from this to control when the hive unit calls for hot water. While there seems to be no way to directly connect to the resol system, I have been able to configure resol to publish the required sensor value to https://www.vbus.net/scheme/f5ddfec4ba41c86c7c5c7fd52e829dbc
The value I want is on the top left of this link.
Can somebody advise how do I configure the scrape sensor to read this data?
Maybe this helps.
Hi, had found that link alright. Unfortunately though its all way over my head.
