Pierre
November 25, 2018, 9:54am
1
Hi there !
I have many temperature/hydro sensors that send data (HF) to an arduino gateway connected to my raspberry pi thru USB (next step will be to use ext IO as serial to avoid the USB cable).
https://www.fabriqueurs.com/poc-domotique-arduino-raspberry-pi/
I would like to split all the information sent by my sensors in order to manage them independently in HA: Have a dedicated history graph or item in the dashboard, for each information receive in the serial port (temperature in garage, hydro in bed room, …, ).
I did a first version using a pyphon script that read the serial port and send data to the MQTT broker but I’m looking for a simplest way (using sensor template ?).
The Arduino gateway send in jason format the information (received in HF by all sensors) to the serial port:
{“capt_info”:{“Type”:“DHT22”,“id”:“S2”},“capt_value”:{“Temp”:“21.0”,“Hydro”:“49.20”}}
{“capt_info”:{“Type”:“DHT22”,“id”:“S1”},“capt_value”:{“Temp”:“18.1”,“Hydro”:“58.30”}}
Any help would be appreciated,
Pierre
Pierre
November 25, 2018, 3:32pm
2
Got it! Templates were the solution.
# Sensors
# serial sensor
- platform: serial
#serial_port: /dev/ttyUSB0
serial_port: /dev/ttyAMA0
sensors:
# split values from serial sensor
temperature_s1:
friendly_name: "Température Maison"
value_template: >
{% if (states.sensor.serial_sensor.attributes["capt_info"]["id"] == "S1") -%}
{{ states.sensor.serial_sensor.attributes["capt_value"]["Temp"] }}
{% else -%}
{{ states.sensor.temperature_s1.state }}
{% endif -%}
temperature_s2:
friendly_name: "Température Garage"
value_template: >
{% if (states.sensor.serial_sensor.attributes["capt_info"]["id"] == "S2") -%}
{% else -%}
{{states.sensor.temperature_s2.state}}
{% endif -%}
temperature_s3:
friendly_name: "Température ext"
value_template: >
{% if (states.sensor.serial_sensor.attributes["capt_info"]["id"] == "S3") -%}
{% else -%}
{{states.sensor.temperature_s3.state}}
{% endif -%}
hydrometrie_s1:
friendly_name: "Humidité Maison"
value_template: >
{{ states.sensor.serial_sensor.attributes["capt_value"]["Hydro"] }}
{% else -%}
{{ states.sensor.hydrometrie_s1.state }}
{% endif -%}
hydrometrie_s2:
friendly_name: "Humidité Garage"
value_template: >
{% else -%}
{{ states.sensor.hydrometrie_s2.state }}
{% endif -%}
hydrometrie_s3:
friendly_name: "Humidité ext"
value_template: >
{% else -%}
{{ states.sensor.hydrometrie_s3.state }}
{% endif -%}
Thank you for sharing this, it looks very elegant!
I’m trying to extract the sensor number out of this string (sensor.serial_sensor):
output for the first sensor: 1+1812.50+22.9+1
output for the second sensor: 2+1805.06+22.7+1
etc.
I can’t figure out how to split my string sensor.serial_sensor. Something like
‘sensor.serial_sensor.split(’+')[0] ’
Gives the correct sensor number, but I can’t figure out how to incorporate that line of code line into your example to base an if statement on it.
Hobby4life
(Hobby4Life)
February 12, 2021, 5:52pm
4
Hi Guys,
Maybe you could help me…
I have a sensor that sends out:
“Z 01234 z 01234”
How can I split these 2 numbers into 2 numeric values?
I have studied your template, but can not see how this is done.
jwm
February 13, 2021, 12:22am
5
Hobby4life:
“Z 01234 z 01234”
Here you go:
{% set var = "Z 01234 z 5678" | regex_replace(find="z ", replace="", ignorecase=True) %}
{% set list = var.split(' ') %}
{{ list[0] | int }} - {{ list[1] | int }}
Result:
1234 - 5678
Hobby4life
(Hobby4Life)
February 13, 2021, 6:49pm
6
Hi thanks for the reply.
Honestly I do not see (yet) how to implement this to my needs.
Thats due the lack of knowledge, but we will get there.
So what I think it does.
it finds any z + space (not case sensitive.) then replaces (deletes) this part.
Then you set up 2 variables?, and split them at the last remaining space?
make a new string with the 2 variables divided by a “-” sign.
In the past I seemed to got the UART working following the UART Text sensor example.
But at the moment I do not seem to get this working again.
Should I do this part in ESPhome on the device itself? or should I do in HA?
This is my part of code I use to read out the raw sensor data:
esphome:
platform: ESP8266
board: d1_mini
includes:
- uart_read_line_sensor.h
wifi:
fast_connect: true
networks:
- ssid: !secret wifi_ssid
hidden: true
ap:
ssid: "Test Fallback Hotspot"
captive_portal:
logger:
# Enable Home Assistant API
api:
ota:
uart:
tx_pin: D1
rx_pin: D2
baud_rate: 9600
text_sensor:
- platform: custom
lambda: |-
auto my_custom_sensor = new UartReadLineSensor(id(uart_bus));
App.register_component(my_custom_sensor);
return {my_custom_sensor};
text_sensors:
Hobby4life
(Hobby4Life)
February 14, 2021, 7:18pm
7
I have got this working in HA
Values where stored starting in list 1 and then list 2, not list 0…
But can I do this directly on the device?
sensors:
co2_converter:
unit_of_measurement: "ppm"
friendly_name: "Co2 value"
value_template: >-
{% set var = states.sensor.co2_raw.state | regex_replace(find="z ", replace="", ignorecase=True) %}
{{ list[1] | int }}
