How to stop 2nd action in automation under certain conditions
I have an automation which turns on the light in hallway when the front door opens and after 5 minutes it turn it off. How can I prevent it from turning off when it is me, that comes home?
- id: '1548545104415'
  alias: Prizgi luč v predsobi, ko se odprejo vhodna vrata, če je temno.
  - entity_id: binary_sensor.vhodna_vrata
    platform: state
    to: 'on'
  condition:
  - below: '5'
    condition: numeric_state
    entity_id: sensor.predsoba_illuminance
  - data: {}
    entity_id: light.pred_soba
    service: light.turn_on
  - delay: 00:05:00
  - data: {}
    service: light.turn_off
What is the entity id of the sensor that detects you are home?
I am using bluetooth presence.
What is the entity_id ?
Probably this:
entity_id: person.peter
If that is your entity you can do something like this:
    platform: state
    to: 'on'
  condition:
  - below: '5'
  - data: {}
  - delay: 00:05:00
  - condition:
      entity_id: 'person.peter'
      state: 'not_home'
  - data: {}
You may need to adjust the state for what it should be but that is close to what you need. There is documentation on this here. The one thing to remember is that any action placed after the condition will not execute. Also this won’t 100% solve the problem because if you are home and someone else opens the door the light will remain on. Since your trigger isn’t your person arriving home it will be difficult to track “who” opened the door and when to turn the light off after 5 mins.
Thanks, but there seems to be a problem, I get the following error:
Invalid config for [automation]: [condition] is an invalid option for [automation]. Check: automation->action->2->condition. (See /config/configuration.yaml, line 140). Please check the docs at https://home-assistant.io/components/automation/
As for the other part, it really isn’t a problem since this light is mostly always turned on when I am at home, but thanks for pointing it out.
It was missing the condition type. Try this:
  - data: {}
  - delay: 00:05:00
  - condition: state
    state: 'not_home'
  - data: {}
Thanks, that fixed the error.
