I have multiple automations and a physical and virtual switch which can turn my hallway lights on/off.
I need to stop them all interfering with each other, and so need to maintain some state/property “on” the light, to know what turned it on.
For example, if the motion detector turns it on, i want it to be turned off after 30s.
But, if the light is already on, and the motion detector triggers, i can either turn it on again (no-op), or choose not to because its already on - ok. But when the occupancy clears, I want to turn the light off, but only if it was the occupancy detector that turned it on in the first place.
This is just one example, there are many use cases.
What the best way to store the state? Do I need to make a helper “variable” and maintain the state in there? But then I need to make a separate helper for every device affected this way, doesnt seem elegant.
Is there a built in mechanism for this im missing?
