How to turn leds on or off according to the air quality state
Hi all, I have air quality sensors attached to a esp32 and I’m using it with esphome.
I also have three leds (red, yellow and green) attached to it.
I would like to show the air quality status with the leds, but I’m struggling with my code to get it working. I have tried the code first with one led but esphome doesn’t like it at all. What’s wrong?
Could you please help me?
output:
  - platform: ledc
    pin: GPIO25
light:
  - platform: monochromatic
    output: red_led
    internal: false
    restore_mode: ALWAYS_ON
    on_state:
      then:
        - if:
            condition:
              lambda: 'return id(iaq).state >= 351;'
            then:
              - light.turn_on: red_onoff
            else:
        - light.turn_off: red_onoff
That on_state defined for your light is only triggered if the light changes, but I guess you want that the other way round, i.e. if the air quality sensor changes then you want to chage the light?
Sensors can define on_value to trigger an action whenever the sensor value changes.
Hi @exxamalte, yes exactly like you described.
I have the following code to show the quality. Can I implement the on_value there and how?
  - platform: wifi_signal
    name: "Kitchen Sensor WiFi Signal"
    update_interval: 60s
  - platform: uptime
    name: "Kitchen Sensor Uptime"
  - platform: bme680_bsec
    bme680_bsec_id: "bme680_internal"
    temperature:
      # Temperature in °C
      name: "Kitchen Sensor BME680 Temperature"
      sample_rate: lp
      filters:
        - median
    pressure:
      # Pressure in hPa
      name: "Kitchen Sensor BME680 Pressure"
      sample_rate: lp
      filters:
        - median
    humidity:
      # Relative humidity %
      name: "Kitchen Sensor BME680 Humidity"
      sample_rate: lp
      filters:
        - median
    gas_resistance:
      # Gas resistance in Ω
      name: "Kitchen Sensor BME680 Gas Resistance"
      filters:
        - median
    iaq:
      # Indoor air quality value
      name: "Kitchen Sensor BME680 IAQ"
      filters:
        - median
    name: "Kitchen Sensor BME680 IAQ Classification"
    icon: "mdi:checkbox-marked-circle-outline"
    lambda: |-
      if ( int(id(iaq).state) <= 50) {
        return {"Excellent"};
      else if (int(id(iaq).state) >= 51 && int(id(iaq).state) <= 100) {
        return {"Good"};
      else if (int(id(iaq).state) >= 101 && int(id(iaq).state) <= 150) {
        return {"Lightly polluted"};
      else if (int(id(iaq).state) >= 151 && int(id(iaq).state) <= 200) {
        return {"Moderately polluted"};
      else if (int(id(iaq).state) >= 201 && int(id(iaq).state) <= 250) {
        return {"Heavily polluted"};
      else if (int(id(iaq).state) >= 251 && int(id(iaq).state) <= 350) {
        return {"Severely polluted"};
      else if (int(id(iaq).state) >= 351) {
        return {"Extremely polluted"};
      else {
        return {"error"};
According to the documentation you should be able to add the on_value bit to each of the sensors, so in your particular case:
    iaq:
      filters:
        - median
      on_value:
        then:
          - if:
              condition:
                lambda: 'return x >= 351;'
              then:
              else:
(I haven’t actually tested this myself, just stitched together from your code.)
Yes, it worked after minor change to the code. Thank you!
Please find the code below. Any optimization suggestions?
    iaq:
      filters:
        - median
      on_value:
        then:
          - if:
              condition:
                lambda: 'return x >= 201;'
              then:
              else:
          - if:
              condition:
                lambda: 'return x <= 200;'
              then:
                - light.turn_on: yellow_onoff
              else:
                - light.turn_off: yellow_onoff
          - if:
              condition:
                lambda: 'return x >= 101;'
              then:
              else:
          - if:
              condition:
                lambda: 'return x <= 100;'
              then:
                - light.turn_on: green_onoff
              else:
                - light.turn_off: green_onoff
How can combine these two? Now red and also yellow lights are on if value is over 200.
          - if:
              condition:
              then:
              else:
          - if:
              condition:
              then:
              else:
I believe I solved it myself:
      on_value:
        then:
          - if:
              condition:
              then:
              else:
          - if:
              condition:
                lambda: 'return x <= 200; return x >= 101;'
              then:
              else:
          - if:
              condition:
              then:
              else:
Isn’t the last return just dead code? When the first return returns, the second should never be reached.
I think, it should be:
 lambda: 'return x <= 200 && x >= 101;'
Yes, you are right, it didn’t work.
I changed it to the below after I noticed I didn’t work. Yours is even better, I will use that, thank you!
lambda: 'return (int(id(iaq).state) >= 101 && int(id(iaq).state) <= 200);'
So here’s (hopefully) the final code:
    iaq:
      filters:
        - median
      on_value:
        then:
          - if:
              condition:
              then:
              else:
          - if:
              condition:
              then:
              else:
          - if:
              condition:
              then:
              else:
