How to turn off/on bulb when I close phone to the same tag
Hi guys
I would like to create automation in HA to turn off/on bulb when I close my phone to tag.
So, for I am using scene (this scene just do bulb ON) in HA then in iOS I create shortcut where I activate scene from HA, then I create automation which is activated by close to tog.
This is working, but I can only turn ON bulb, in this scenario I would need to create another scene in HA to turn off bulb - to me this is looks like duplicate things.
I would like to use just one tag to turn off and on.
Could you please review my approach ? Maybe it is overkill and I can have this easier?
Instead of activating a scene use the light.toggle action.
Thank you @tom_l
your advise works - now every time I close phone to tag bulb is on or off
Hi @tom_l
Now, I noticed strange thing.
When my automation is enabled in HA, then switch for bulb does not work correct on dashboard.
When I try switch on it switch for 1 sec and go off.
Once I turn off automation switch working fine.
Share your automation yaml correctly formatted for the forum.
Hi @tom_l
This is my automation
alias: lrb1
description: switch bulb 1 on or off
triggers:
  - trigger: state
    entity_id:
      - light.innr_rb_279_t_light
conditions:
  - condition: state
    entity_id: light.innr_rb_279_t_light
    state: "on"
actions:
  - action: light.toggle
    metadata: {}
      kelvin: 2533
      brightness_pct: 25
mode: single
You are triggering on any change of the light state. You need to trigger on the tag scanned event.
And remove the condition.
Not sure how can I trigger for tag scan in HA.
Right now I have setup automation in iOS which is trigger when I scan tag. Should I scan tag in HA instead of iOS automation?
Does that have a light toggle instead of light turn on action?
Then you would not need the home assistant automation at all.
I can not add this bulb to ios - I can only use it in HA - this bulb can connct to zigbee 3,0 USB which is integrated with HA. So, I think I need HA
You can add any home assistant light to HomeKit.
Thank you - integrated HA wit HomeKit and now automation working good - and switch in HA also
Thank you
