How to turn off wake word detection on M5 Echo
before, we had a toggle to control Use wake word or not
Ive finally managed to get the M5 Echo to run the latest firmware at wake-word-voice-assistants/m5stack-atom-echo/m5stack-atom-echo.yaml at 5a2aff4b9a85ffef728a65666cd40badc8791ef3 · esphome/wake-word-voice-assistants · GitHub
but now its always listening and no option to turn off?
I dont want that (I just want to use the button), so please help me find a way to realize that again?
this is what I get now
Same question here…
I’ve fixed it help from BigBobba in Discord Discord
this is my yaml now, it adds a switch for the wake word, and a script action to turn off the light in case
(I also have several sensors on the device for memory and connection time, so be sure to take those out if you dont need them,)
substitutions:
  friendly_name: M5Stack Atom Echo
  micro_wake_word_model: okay_nabu  # alexa, hey_jarvis, hey_mycroft are also supported
esphome:
  name_add_mac_suffix: false
  friendly_name: ${friendly_name}
  min_version: 2025.2.0
api:
  encryption:
    key: !secret encryption_key_echo
wifi:
  ssid: !secret wifi_ssid
esp32:
  board: m5stack-atom
  framework:
    type: esp-idf
    version: 4.4.8
    platform_version: 5.4.0
logger:
ota:
  - platform: esphome
  # Uptime sensor.
  - platform: uptime
    name: ${name} wifi uptime
    name: ${name} Free Memory
    lambda: return heap_caps_get_free_size(MALLOC_CAP_INTERNAL);
    unit_of_measurement: B
    state_class: measurement
captive_portal:
button:
  - platform: factory_reset
i2s_audio:
  - id: i2s_audio_bus
    i2s_lrclk_pin: GPIO33
    i2s_bclk_pin: GPIO19
microphone:
  - platform: i2s_audio
    i2s_din_pin: GPIO23
    adc_type: external
    pdm: true
speaker:
    i2s_dout_pin: GPIO22
    dac_type: external
    bits_per_sample: 32bit
    channel: right
    buffer_duration: 60ms
media_player:
  - platform: speaker
    announcement_pipeline:
      speaker: echo_speaker
      format: WAV
    codec_support_enabled: false
    buffer_size: 6000
    files:
      - id: timer_finished_wave_file
        file: https://github.com/esphome/wake-word-voice-assistants/raw/main/sounds/timer_finished.wav
    on_announcement:
      - if:
          condition:
            - microphone.is_capturing:
          then:
            - if:
                condition:
                  lambda: return id(wake_word_engine_location).state == "On device";
                then:
                  - micro_wake_word.stop:
                else:
                  - voice_assistant.stop:
            - script.execute: reset_led
      - light.turn_on:
          blue: 100%
          red: 0%
          green: 0%
          brightness: 100%
          effect: none
    on_idle:
      - script.execute: start_wake_word
voice_assistant:
  microphone: echo_microphone
  media_player: echo_media_player
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  on_listening:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Slow Pulse"
  on_stt_vad_end:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Fast Pulse"
  on_tts_start:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        brightness: 100%
        effect: none
  on_end:
    - delay: 100ms
  on_error:
    - light.turn_on:
        red: 100%
        green: 0%
        blue: 0%
        brightness: 100%
        effect: none
    - delay: 2s
  on_client_connected:
    - delay: 2s  # Give the api server time to settle
  on_client_disconnected:
  on_timer_finished:
    - wait_until:
        not:
    - switch.turn_on: timer_ringing
    - light.turn_on:
        red: 0%
        green: 100%
        blue: 0%
        brightness: 100%
    - wait_until:
        - switch.is_off: timer_ringing
    - light.turn_off: led
    - switch.turn_off: timer_ringing
binary_sensor:
  # button does the following:
  # short click - stop a timer
  # if no timer then restart either microwakeword or voice assistant continuous
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
    disabled_by_default: true
    entity_category: diagnostic
    on_multi_click:
      - timing:
          - ON for at least 50ms
          - OFF for at least 50ms
        then:
          - if:
              condition:
                switch.is_on: timer_ringing
              then:
              else:
                if:
                  condition:
                    - lambda: return id(wake_word_engine_location).state == "Disabled";
                  then:
                    - voice_assistant.start_continuous:
                  else:
      - timing:
          - ON for at least 10s
        then:
          - button.press: factory_reset_btn
light:
  - platform: esp32_rmt_led_strip
    entity_category: config
    pin: GPIO27
    default_transition_length: 0s
    chipset: SK6812
    num_leds: 1
    rgb_order: grb
    rmt_channel: 0
    effects:
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
script:
  - id: reset_led
    then:
      - if:
          condition:
            - lambda: return id(wake_word_engine_location).state == "In Home Assistant";
            - switch.is_on: use_listen_light
          then:
            - light.turn_on:
                red: 100%
                green: 89%
                blue: 71%
                brightness: 60%
                effect: none
          else:
            - if:
                condition:
                  - lambda: return id(wake_word_engine_location).state != "On device";
                then:
                  - light.turn_on:
                      red: 0%
                      green: 100%
                      blue: 100%
                      brightness: 60%
                      effect: none
                else:
                  - if:
                      condition:
                        - lambda: return id(wake_word_engine_location).state != "Disabled";
                      then:
                        - light.turn_on:
                            red: 50%
                            green: 50%
                            blue: 80%
                            brightness: 60%
                            effect: none
                      else:
  - id: start_wake_word
    then:
      - wait_until:
          and:
            - media_player.is_idle:
            - speaker.is_stopped:
      - if:
          condition:
          then:
            - delay: 1s
            - script.wait: reset_led
            - micro_wake_word.start:
          else:
            - if:
                condition:
                then:
                  - delay: 100ms
                  - lambda: id(va).set_use_wake_word(true);
                  - delay: 100ms
                else:
                  - if:
                      condition:
                        and:
                          - voice_assistant.is_running
                      then:
switch:
    name: Use listen light
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on:
    on_turn_off:
    optimistic: true
    restore_mode: ALWAYS_OFF
    on_turn_off:
      # Turn off the repeat mode and disable the pause between playlist items
      - lambda: |-
              id(echo_media_player)
                ->make_call()
                .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_OFF)
                .set_announcement(true)
                .perform();
              id(echo_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 0);
      # Stop playing the alarm
      - media_player.stop:
          announcement: true
    on_turn_on:
      # Turn on the repeat mode and pause for 1000 ms between playlist items/repeats
      - lambda: |-
              ->make_call()
              .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_ONE)
              .perform();
            id(echo_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 1000);
      - media_player.speaker.play_on_device_media_file:
          media_file: timer_finished_wave_file
          announcement: true
      - delay: 15min
select:
    name: Wake word engine location
    optimistic: true
    restore_value: true
    options:
      - In Home Assistant
      - On device
      - Disabled
    initial_option: On device
    on_value:
      - if:
          condition:
            lambda: return x == "In Home Assistant";
          then:
            - delay: 500ms
      - if:
          condition:
            lambda: return x == "On device";
          then:
            - lambda: id(va).set_use_wake_word(false);
            - delay: 500ms
            - switch.turn_on: use_listen_light
      - if:
          condition:
            lambda: return x == "Disabled";
          then:
            - delay: 500ms
            - switch.turn_off: use_listen_light
micro_wake_word:
  on_wake_word_detected:
    - voice_assistant.start:
        wake_word: !lambda return wake_word;
  vad:
  models:
    - model: ${micro_wake_word_model}
