How to turn on LEDs driven by ESP32 GPIOs but dimmed?
I have the following code defining the LED:
output:
  - platform: ledc
    pin: GPIO4
    frequency: 1000 Hz
    inverted: false
light:
  - platform: monochromatic
    output: led
    restore_mode: ALWAYS_OFF
    on_turn_on:
      - output.set_level:
          level: 0.25
    on_turn_off:
      - output.set_level:
          level: 0.0
and from elsewhere I use a lambda and try to turn it on with:
id(blue_led).turn_on();
but nothing happens. It does not light up. If I call id(led).turn_on(); directly, then it turns on, but its full brightness.
How can I turn it on so that its like 25% brightness. I dont care about being able to control it from home assistant. I just want it to never be brighter than 25% . This is a blue LED and its eye piercing! :eye::dark_sunglasses:
Post all of the ESPHome yaml configuration.
Is the blue LED on GPIO4 and you always want it at 25%? Then use this:
output:
  - platform: ledc
    pin: GPIO4
    frequency: 1000 Hz
    inverted: false
    duty_cycle: 0.25
Or if you need to use light component, remove all the on_turn_… automations and call the light:
id(blue_led).turn_on().set_brightness(0.25).perform();
Ive tried that but get this compilation error:
 platform: ledc
  pin: GPIO4
  frequency: 1000 Hz
  inverted: False
  [duty_cycle] is an invalid option for [output.ledc]. Please check the indentation.
  duty_cycle: 0.25
This worked! Thanks!
You’re welcome.
