How to update the color of an arc attached to a lvgl meter object during runtime
I am using lvgl with an EspHome based Waveshare Display. All this is working perfectly.
One of the LVGL widgets is a meter with 24 indicator arcs (price_1 to price_24), where I want to set the color dynamically during runtime. I simply can’t find a way to do that. Neither using standard yaml nor using a lambda function. But I simply can’t find the right syntax. Can this be done in the current implementation of LVGL in ESPHome?
I have tried things like:
  - lvgl.indicator.update:
      color: 0x4CAF50
Here is a snippet of the meter definition:
                    - meter:
                        width: 350
                        height: 350
                        align: CENTER
                        bg_opa: TRANSP
                        border_width: 0
                        text_color: color_light_gray
                        indicator:
                          bg_color: color_red
                        scales:
                          - range_from: 0
                            range_to: 60
                            angle_range: 360
                            rotation: 270
                            ticks:
                              count: 0
                            indicators:
                              - line:
                                  width: 2
                                  r_mod: -17
                                  value: 0
                          - range_from: 0
                            range_to: 23
                            angle_range: 345
                            rotation: 270
                            ticks:
                              count: 24
                              width: 1
                              length: 1
                              major:
                                stride: 1
                                width: 2
                                length: 15
                                color: color_white
                                label_gap: 18
                            indicators:
                              - arc:
                                  color: color_dark_gray
                                  start_value: 0
                                  end_value: 1
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 1
                                  end_value: 2
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 2
                                  end_value: 3
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 3
                                  end_value: 4
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 4
                                  end_value: 5
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 5
                                  end_value: 6
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 6
                                  end_value: 7
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 7
                                  end_value: 8
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 8
                                  end_value: 9
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 9
                                  end_value: 10
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 10
                                  end_value: 11
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 11
                                  end_value: 12
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 12
                                  end_value: 13
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 13
                                  end_value: 14
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 14
                                  end_value: 15
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 15
                                  end_value: 16
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 16
                                  end_value: 17
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 17
                                  end_value: 18
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 18
                                  end_value: 19
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 19
                                  end_value: 20
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 20
                                  end_value: 21
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 21
                                  end_value: 22
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 22
                                  end_value: 23
                                  width: 15
                                  r_mod: 0
                              - arc:
                                  start_value: 23
                                  end_value: 0
                                  width: 15
                                  r_mod: 0
                          - range_from: 0
                            range_to: 1440
                            angle_range: 360
                            rotation: 270
                            ticks:
                              count: 0
                            indicators:
                              - line:
                                  width: 3
                                  r_mod: -45
                                  value: 0
Try
- lvgl.arc.update:
    arc_color: 0x4CAF50
Thanks for your suggestion. Unfortunately this does not work, as the arc indicator that belongs to a meter object does not have the arc_color parameter, only color.
Here is the error it throws:
ID 'price_1' of type lv_meter_indicator_t doesn't inherit from lv_arc_t.
Right, sorry for that.
The indicator.update you tried looks correct. What error you got with that?
I get this error: [color] is an invalid option for [lvgl.indicator.update]. Please check the indentation.
It seems that indicators can only update the value, and not the settings. But I hope I am wrong.
Try something creative like
lvgl.indicator.arc.update
Good creative suggestion. I tried lvgl.indicator.arc.update, lvgl.meter.indicator.arc.update and lvgl.meter.arc.update but unfortunately they all come back with Unable to find action with the name ...
It’s not possible - the LVGL library does not have a function to update the colour of an indicator.
Instead of using indicator arcs, why not draw arc widgets instead, using align: center?
Thanks Clyde. I somehow guessed this was the answer.
I went with your idea on using the arc directly, and I am making some progress there. I will post my result when done.
any luck with this?
YES. I managed to get it to work. It is quite a big project, so I can’t post everything here. But in essence here are a few code snippets:
Define the LVGL Circular clock, divided into 24 segments:
              - obj:
                  styles: widget_style_6x12
                  bg_color: color_bg
                  grid_cell_column_pos: 3
                  grid_cell_row_pos: 0
                  grid_cell_column_span: 6
                  grid_cell_row_span: 12
                  grid_cell_x_align: CENTER
                  grid_cell_y_align: CENTER
                  pad_all: 0
                  pad_left: 5
                  widgets:
                    # Container for the arc widgets (price display)
                    - obj:
                        width: 100%
                        height: 100%
                        bg_opa: TRANSP
                        border_width: 0
                        pad_all: 0
                        widgets:
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 270
                              end_angle: 285
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                              arc_color: color_dark_gray
                              adv_hittest: true
                              clickable: true
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 285
                              end_angle: 300
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 300
                              end_angle: 315
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 315
                              end_angle: 330
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 330
                              end_angle: 345
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 345
                              end_angle: 0
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 0
                              end_angle: 15
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 15
                              end_angle: 30
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 30
                              end_angle: 45
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 45
                              end_angle: 60
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 60
                              end_angle: 75
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 75
                              end_angle: 90
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 90
                              end_angle: 105
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 105
                              end_angle: 120
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 120
                              end_angle: 135
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 135
                              end_angle: 150
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 150
                              end_angle: 165
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 165
                              end_angle: 180
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 180
                              end_angle: 195
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 195
                              end_angle: 210
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 210
                              end_angle: 225
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 225
                              end_angle: 240
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 240
                              end_angle: 255
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
                          - arc:
                              arc_opa: COVER
                              width: 100%
                              height: 100%
                              start_angle: 255
                              end_angle: 270
                              arc_width: 25
                              arc_rounded: false
                              rotation: 360
                              value: 0
                              adjustable: false
And here is the part of a script that sets the right color. Please note it call’s some homemade C++ functions to define the color and other stuff I want to use, but the function to use is lv_color_make(225, 225, 225) replacing 225, 225, 225 with the RGB color you want.
  - id: update_price_page_clock
    then:
      if:
        condition:
          - lambda: return id(price_data_loaded);
        then:
          - lambda: |-
              auto now = id(sntp_time).now();
              int current_hour = now.hour;
              // LOOP THROUGH THE AVAILABLE DATA
              for (int i = 0; i < 24; i++) {
                if (i < current_hour && !id(tomorrow_data_valid)) {
                  lv_label_set_text_fmt(id(price_labels_view)[i], "Waiting");
                  lv_obj_set_style_text_color(id(price_labels_view)[i], lv_color_make(225, 225, 225), LV_PART_MAIN);
                } else {
                  auto cur_color = getColorFromValue(id(prices)[i]);
                  lv_obj_set_style_text_color(id(price_labels_view)[i], cur_color, static_cast<lv_part_t>(LV_PART_MAIN) | static_cast<lv_state_t>(LV_STATE_DEFAULT));
                  lv_label_set_text_fmt(id(price_labels_view)[i], "%s kr", formatFloat2dec(id(prices)[i]).c_str());
                  if (i < current_hour && id(tomorrow_data_valid)) {
                    lv_obj_set_style_text_opa(id(price_labels_view)[i], 204, LV_PART_MAIN);
                  } else {
                    lv_obj_set_style_text_opa(id(price_labels_view)[i], 255, LV_PART_MAIN);
              // MARK THE CURRENT HOUR
                if (i == current_hour) {
                  lv_label_set_text_fmt(id(price_times)[i], "#2097F3 ${arrow_right}# #E1E1E1 %s#", formatHighLowTime(i).c_str());
                } else {
                  lv_label_set_text_fmt(id(price_times)[i], "%s", formatHighLowTime(i).c_str());
As I wrote, this is part of a big project, so I cannot post the entire code base, but hopefully this can point you in the right direction.
Just a fyi, i found a way to change the color of a line, maybe similar exists for arc?
id(second_hand)->type_data.needle_line.color = Color::random_color();
Just in case anyone stumbles upon this:
LVGL has a function to update the indicator part, it can be called from a lambda:
- lambda: lv_obj_set_style_arc_color(your_arc_id, your_color, LV_PART_INDICATOR | LV_STATE_DEFAULT);
The LV_PART_INDICATOR defines that the indicator part is updated. Not sure about LV_STATE_DEFAULT - might not be needed
