How to upgrading via the 'pip install --upgrade pip' command
hi
from the addon Check Home Assistant configuration
following the how to use instructions nb 3
Check the add-on log output to see the result.
i got this :
starting version 3.2.8
[13:46:17] INFO: Don’t worry, this temporary installation is not overwriting your current one.
[13:46:17] INFO: Installing Home Assistant: latest…
[13:46:17] INFO: Please be patient, this might take a few minutes…
WARNING: You are using pip version 19.2.2, however version 19.3.1 is available.
You should consider upgrading via the ‘pip install --upgrade pip’ command.
[13:49:52] INFO: Installed Home Assistant 0.102.1
[13:49:52] INFO: Making a copy of your configuration for checking…
[13:50:32] INFO: Checking your configuration against this version…
[13:57:56] INFO: Configuration check finished - no error found! :slight_smile:
how to do that ?
Thanks for your help
If you’re running HASSIO you absolutely, 100% DO NOT need to run anything. If you’re running an ADD-ON, that means you’re running HASSIO which means you do nothing of the sort.
You can ignore that message
