I am trying to build a voice-driven automation which will play music on a specified media player, but where the target media player is determined by the Area in which the voice assistant device is location. I’m using Atom Echo speakers for this purpose.
So for example, if I issue the command to the Atom Echo in the kitchen, the music will play on the media player in the kitchen.
The automation is currently able to play music to a specified (i.e. hard-coded) media player (i.e. in the study in the example below), but I’m struggling with the syntax to make the media_player if variable depending on area_name(trigger.device_id)
Can anyone provide any pointers?
Here is my existing automation, which plays music on my study media player and correctly notifies my phone of the area from which the command originated:
alias: Voice command to play track (device aware)
description: ""
triggers:
- command:
- play {track_name}
trigger: conversation
conditions: []
actions:
- action: script.music_search_first_match
metadata: {}
search_query: "{{ trigger.slots.track_name }}"
match_type: first
media_content_type: Tracks
media_player: media_player.study_speaker_lms_castbridge
- action: notify.mobile_app_ian_galaxy_s24_ultra
metadata: {}
message: "{{ area_name(trigger.device_id) }}"
mode: single
Unfortunately, that can give you the wrong player if you have Areas with multiple media_player entities, which is pretty common. So, a better option might be to add a label to any media player you want to use with this type of script then use that in the selection:
{{ area_entities(area_id(trigger.device_id))
| select('in', label_entities('Selected Media Players')) | first }}
My automation now looks like this, but the media_player id is not being rendered. This is what the Trace shows:
params:
domain: script
service: music_search_first_match
service_data:
search_query: you only live once
match_type: first
media_player:
'[object Object]': null
The value of area_id(trigger.device_id) is Bedroom
This is what the automation looks like:
description: ""
triggers:
- command:
- play {track_name}
conditions: []
actions:
metadata: {}
match_type: first
media_player:
{{ area_entities(area_id(trigger.device_id)))
metadata: {}
mode: single
Could it be that the media_player name is case-sensitive? i.e. do I need to rename the “Bedroom” area as “bedroom”?
