So I have this message working (mostly)
- service: script.audio_notify
data_template:
tts_msg: "The {{ trigger.to_state.attributes.friendly_name }} is: {{ trigger.to_state.state }}"
mplayer: "main"
But it says, the Front door is ON, or Window is OFF, etc.
Makes sense since that is the state. Without creating another sensor, how do I get it to say Open ,instead of On, and closed instead of off?
data_template:
tts_msg: >-
The {{ trigger.to_state.name }} is:
{%- if trigger.to_state.state in ['on', 'off'] -%}
{{ {'on': ' open', 'off': ' closed'}[trigger.to_state.state] }}
{%- else -%}
{{ ' unknown' }}
{%- endif %}
mplayer: "main"
Note that trigger.to_state.name is a shortcut for trigger.to_state.attributes.friendly_name.
Thank you very much, Iβm going to use this for my water leak automation as well.
- alias: Doors or windows left opened
platform: state
entity_id: binary_sensor.open_close_sensor_back_door,binary_sensor.open_close_sensor_front_door,binary_sensor.open_close_sensor_garage_door,binary_sensor.living_room_window_open_close,binary_sensor.office_window_open_close
to: 'on'
for:
minutes: 2
condition:
- condition: numeric_state
entity_id: sensor.ha_runtime_in_minutes
above: 1
- condition: state
entity_id: group.primary_presence
state: 'on'
data_template:
tts_msg: >-
{%- else -%}
{{ ' unknown' }}
{%- endif %}
mplayer: "main"
- alias: Water Leak Detected
- platform: state
entity_id: binary_sensor.water_sensor_attic,binary_sensor.water_sensor_kitchen
condition:
above: 1
data_template:
tts_msg: >-
{{ {'on': ' Detected a leak.', 'off': ' leak has cleared.'}[trigger.to_state.state] }}
{%- else -%}
{{ ' unknown' }}
{%- endif %}
mplayer: "all"
Hmm, for the first automation this seems a bit unnecessary. I.e., the automation only triggers when one of the entities is βonβ for two minutes, so trigger.to_state.state is only ever going to be βonβ. So this should do:
platform: state
to: 'on'
for:
minutes: 2
condition:
above: 1
- condition: state
state: 'on'
data_template:
tts_msg: "The {{ trigger.to_state.name }} is open."
mplayer: "main"
Good call, I forgot i had changed the trigger. Initially I had it set to any state change, but it got annoying pretty quick. haha.
