I’ve updated and fixed some issue with my previous code. Using the Hue app, when I update the color of a light, the associated smart switch will be turn on automatically
import json
from appdaemon.adbase import ADBase
import voluptuous as vol
from constants import APP_MIN_SCHEMA
APP_SCHEMA = APP_MIN_SCHEMA.extend(
vol.Required("name"): str,
vol.Required("light"): str,
vol.Required("switch"): str,
vol.Required("unique_id"): str,
class MqttLight(ADBase):
def initialize(self):
self.args = APP_SCHEMA(self.args)
self.hass = self.get_plugin_api("HASS")
self.mqtt = self.get_plugin_api("MQTT")
self.light = self.args["light"]
self.switch = self.args["switch"]
entity = str.lower(str.replace(self.args["name"], " ", "_"))
self.topic = f"homeassistant/light/{entity}"
self.hass.listen_state(self.switch2mqtt, self.switch)
self.hass.listen_state(self.light2mqtt, self.light, attribute="all")
self.mqtt.listen_event(self.set_state, topic=f"{self.topic}/set")
self.publish_light_configuration()
def publish_light_configuration(self):
supported_features = self.hass.get_state(
self.light, attribute="supported_features"
effect_list = self.hass.get_state(self.light, attribute="effect_list")
binary_supported_features = format(supported_features, "08b")
config = {
"~": self.topic,
"name": self.args["name"],
"uniq_id": self.args["unique_id"],
"cmd_t": "~/set",
"stat_t": "~/state",
"schema": "json",
"brightness": binary_supported_features[7] == "1",
"color_temp": binary_supported_features[6] == "1",
"effect": binary_supported_features[5] == "1",
"hs": binary_supported_features[3] == "1",
"white_value": binary_supported_features[0] == "1",
"effect_list": effect_list,
"ret": True,
self.mqtt.mqtt_publish(f"{self.topic}/config", payload=json.dumps(config))
def switch2mqtt(self, entity, attribute, old, new, kwargs):
payload = {"state": str.upper(new)}
self.publish_state(payload)
def light2mqtt(self, entity, attribute, old, new, kwargs):
new_attrs = new["attributes"]
attrs = ["brightness", "color_temp", "white_value"]
payload = {attr: new_attrs[attr] for attr in attrs if attr in new_attrs}
payload["state"] = new["state"].upper()
if "hs_color" in new_attrs:
payload["color"] = {
"h": new_attrs["hs_color"][0],
"s": new_attrs["hs_color"][1],
def set_state(self, event_name, data, kwargs):
if "payload" not in data:
return
payload = json.loads(data["payload"])
if payload.get("state") == "ON":
attrs = ["brightness", "color_temp", "white_value", "effect"]
attributes = {attr: payload[attr] for attr in attrs if attr in payload}
if "color" in payload:
attributes["hs_color"] = [payload["color"]["h"], payload["color"]["s"]]
self.hass.turn_on(self.switch)
self.hass.turn_on(self.light, **attributes)
elif payload.get("state") == "OFF":
self.hass.turn_off(self.switch)
def publish_state(self, payload):
self.mqtt.mqtt_publish(f"{self.topic}/state", payload=json.dumps(payload))
