I control two Nabu Casas, one in the UK and one in South Africa. Both running two different Tailscale Networks. The SA Home Assistant is shared to teh UK Tailscale Network.
The Full Home Assistant Documentation Link is broken so I cannot use that.
I can access the SA HA from the browser on my iPad & iphone via Tailscale. I cannot get the Companion App to find the SA HA on my iPad or iPhone. Neither the Magic Link and IP approach work but give different results.
Can’t see how to attach the logfiles, or do I just paste the text from the log file?
I’d really love to find a document that describes how to set up access from a shared Tailscale Home Assistant to my Tailscale. Or some key pointers
Claudes response to the logfile of the IP attempt 100.72.30.49
Error: NSURLErrorDomain Code=-1004 “Could not connect to the server” (errno 61 = connection refused) at https://100.72.30.49/
What this means: DNS resolved fine this time (no more -1003), but the TCP connection was actively refused. Something is listening for Bonjour on that address but nothing is answering HTTPS on it — likely one of:
**• That IP isn’t actually the HA Green’s Tailscale IP — it may be a stale/cached Bonjour entry for something else on the Tailnet (worth double-checking against Martin’s actual HA Green Tailscale IP)**
**• HA Green’s web server isn’t up/reachable on port 443 at that address right now**
**• A firewall or ACL on the Tailscale network is blocking that port between your device and SA node**
Can you confirm 100.72.30.49 is actually Martin’s Home Assistant Green’s Tailscale IP? And is Tailscale definitely showing “Connected” on your device right now?
“”It is!””
