This is a program I wrote myself, but it prompts an error <Platform not found: ‘sensor.uart’>. The picture below is the communication format. How should I modify the program?
Hi
Please post the whole code/sketch properly quoted so it’s readable not a screen capture
For protocol english version would help !
Vincèn
esphome:
friendly_name: pm_sensor
esp8266:
board: esp01_1m
# Enable Home Assistant API
api:
ota:
- platform: esphome
wifi:
# fast_connect: true
reboot_timeout: 600s
networks:
- ssid: "bgy"
password: "msnmsn321"
ap:
ssid: "pm_sensor"
captive_portal:
logger:
level: info # VERBOSE #makes uart stream available in esphome logstream
baud_rate: 0 #disable logging over uart
web_server:
port: 80
button:
- platform: restart
uart:
rx_pin: GPIO3 # 默认 RX 引脚
tx_pin: GPIO1 # 默认 TX 引脚
baud_rate: 9600
data_bits: 8
parity: NONE
stop_bits: 1
- platform: uart
uart_id: uart_1
on_uart_data: |-
id(pm10_sensor).publish_state((x[4] << 8 | x[5])); # 读取 PM1.0 值
unit_of_measurement: "µg/m³"
- platform: uart
uart_id: uart_1
on_uart_data: |-
id(pm25_sensor).publish_state((x[6] << 8 | x[7])); # 读取 PM2.5 值
- platform: uart
uart_id: uart_1
on_uart_data: |-
id(pm10_sensor).publish_state((x[8] << 8 | x[9])); # 读取 PM10 值
here is the link for communication protocol,in chinese
I don’t believe there’s a UART sensor platform. I think this requires building a component.
You’re correct, although there’s a bit of a hacky workaround by abusing the debug facility of the UART component.
More info here: How to transfer data from uart - #3 by commanderalpha
Fantasy from Chatgpt?
If you want to read uart on Esphome without specific component, the only way afaik is uart debug with dummy receiver.
uart:
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
Do you like to try using an external component?
You can try like this.
uart:
baud_rate: 9600
data_bits: 8
parity: NONE
stop_bits: 1
rx_pin: GPIO3
tx_pin: GPIO1
external_components:
- source: github://eigger/espcomponents/releases/latest
components: [ uartex ]
refresh: always
uartex:
rx_timeout: 10ms
tx_delay: 50ms
tx_timeout: 500ms
tx_retry_cnt: 3
rx_header: [0x42, 0x4D]
# rx_footer: "\r\n"
tx_header: [0x42, 0x4D]
# tx_footer: "\r\n"
# rx_checksum: add
# tx_checksum: add
rx_checksum2: !lambda |-
uint8_t crc_1 = 0;
uint8_t crc_2 = 0;
for (int i = 0; i < len; i++)
crc_1 += data[i];
crc_2 += data[i];
crc_2 += crc_1;
return {crc_1, crc_2};
version:
disabled: False
error:
disabled: False
log:
disabled: False
- platform: uartex
state:
data: [0x00, 0x00]
mask: [0x00, 0x00]
state_number:
offset: 2
length: 2
precision: 2
- platform: uartex
state:
data: [0x00, 0x00]
mask: [0x00, 0x00]
state_number:
offset: 4
length: 2
precision: 2
- platform: uartex
state:
data: [0x00, 0x00]
mask: [0x00, 0x00]
state_number:
offset: 6
length: 2
precision: 2
fork and star!when my PCB is ready, I will verify it immediately
This also seems to work:
Use as:
includes:
- uart_read_line_sensor.h
yes,chatgpt sucks
Please do jot post llm generated code to the forum and ask it ‘it is correct’
First it’s against the forum rules. …see below.
Second llms (all of them, yes even deepseek and grok3 and latest gpt whatever.) are currently glorious at generating code fast… But because the cutoff dates trail current HA by nearly a year. And yes it matters… It causes the llm to generate baloney that LOOKS right.
It then takes the volunteers hours to unwind the BS from real chasing thier tails on garbage.
For that reason please don’t post llm generated code and ask people to debug it… Thanks.
sorry sir, i will note that
