How to use value_template to extract data from the sensor
I have one sensor which as below. Is for checking the SSD temperature on the proxmox server.
  • platform: command_line
    name: SSD Temp on Proxmox
    command: “ssh -i /config/id_rsa -o StrictHostKeyChecking=no [email protected] -t ‘hddtemp /dev/sda’”
which output come out as below but without the quote
“/dev/sda: TS512GMTS430S: 60°C”
what is the correct command of value_template to extract just the value of “60°C” ? I try to seach through the forum but non of the topic match my question.
Thanks in advance.
Please format your code correctly with the </> button.
Easiest way would be to get the command to give you the right output. I don’t have hddtemp to hand, but try these on the proxmox server command line to see if you get just the number reported:
hddtemp -n
hddtemp -n | split -d \  -f 3
Note there are two spaces after the backslash. If one of those gives just a number, put that in the command of your sensor.
If that doesn’t work, you could use:
- platform: command_line
  command: "ssh -i /config/id_rsa -o StrictHostKeyChecking=no [email protected] -t 'hddtemp /dev/sda'"
  unit_of_measurement: "°C"
  device_class: temperature
  unique_id: 2e01043e-d562-4c73-ad46-6778832ed4ed
  value_template: "{{ value|regex_replace('^.*:','')|regex_replace('[^0-9]','') }}"
which takes the value, removes anything before and up to a colon, then removes anything non-numeric from the remainder.
at first, thanks for reply.
hddtemp -n won’t work as it need specify a device
root@proxmox:~# hddtemp -n
Too few arguments: you must specify one drive, at least.
root@proxmox:~# hddtemp /dev/sda
I use below command on HA config file & it successfully generate just the number only.
    unit_of_measurement: “°C”
    value_template: “{{ value|regex_replace(’^.*:’,’’)|regex_replace(’[^0-9]’,’’) }}”
how do you generate that unique_id ? by the way, is that necessarily to specify the device_class?
Please format your code correctly with the </> button. If you don’t we can’t see indentation errors, and all your quotes are converted into smart quotes.
hddtemp -n /dev/sda
should work then? If it does give just a number and no disk label information, you can remove the value_template in the sensor.
unique_id just has to be unique. I use https://www.uuidgenerator.net/. device_class isn’t necessary but it gives you appropriate icons in the UI.
below command working !
root@proxmox:~# hddtemp -n /dev/sda
61
yes, I will remove the value template & use above command. Really thanks for your help :slight_smile:
