Hi, I have tried to get this one working with esphome, but no luck with the display so far. Touch is working, I can get x/y in logs.
Model: https://www.waveshare.com/esp32-s3-touch-lcd-3.5.htm
Wiki: https://www.waveshare.com/wiki/ESP32-S3-Touch-LCD-3.5#Datasheets
Tried with quad spi and single, with mipi driver and ILxxxx.
Code:
esphome:
psram:
mode: octal
speed: 80MHz
esp32:
variant: esp32s3
board: esp32-s3-devkitc-1
flash_size: 16MB
framework:
type: esp-idf
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Ws-35-panel Fallback Hotspot"
password: !secret wifi_ap_password
captive_portal:
# Enable logging
logger:
level: INFO
# Enable Home Assistant API
api:
encryption:
key: !secret api_key
ota:
platform: esphome
password: !secret ota_password
web_server:
port: 80
#spi:
# id: display_qspi
# type: quad
# clk_pin: 5
# data_pins: [1,2,3,4]
spi:
clk_pin: GPIO05
mosi_pin: GPIO01
miso_pin: GPIO02
i2c:
sda: 8
scl: 7
display:
- platform: mipi_spi
model: st7796
spi_id: display_spi
# cs_pin: 6
dc_pin: 3
#reset_pin: EXIO1
rotation: 90
spi_mode: 3
color_order: bgr
pixel_mode: 16bit
auto_clear_enabled: false
update_interval: never
#display:
# - platform: ili9xxx
# model: ST7796
# dc_pin: GPIO03
# invert_colors: False
# #data_rate: 40MHz
# dimensions:
# height: 320
# width: 480
# transform:
# mirror_x: false
# mirror_y: false
# cs_pin:
# number: -1
# ignore_strapping_warning: true
# auto_clear_enabled: false
# update_interval: never
# draw_from_origin: true
# rotation: 0
# init_sequence:
touchscreen:
platform: ft63x6
transform:
swap_xy: true
mirror_x: false
mirror_y: true
on_touch:
- lambda: |-
ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
lvgl:
widgets:
- label:
align: CENTER
text: 'Hello World!'
Karosm
(Karosm)
December 19, 2025, 6:32pm
2
I don’t know your display but just came to my mind, a while ago trying to help someone here with another waveshare display board, touch and lcd reset pins were swapped on the schematics.
Try with exio2.
You haven’t configured the tca9554 I/O Extender, which has the LCD reset pin, so it’s likely holding the LCD controller in reset.
LeifKlasson
(Leif Klasson)
December 30, 2025, 10:09am
4
Thanks @clydebarrow ! That helped and I also checked some Arduino examples to verify setup. Now I got the famous “Hello World” to work!
esphome:
psram:
mode: octal
speed: 80MHz
esp32:
variant: esp32s3
flash_size: 16MB
framework:
type: esp-idf
wifi:
ap:
captive_portal:
# Enable logging
logger:
level: INFO
api:
encryption:
ota:
platform: esphome
web_server:
port: 80
# I2C bus configuration
i2c:
- id: i2c_bus
sda: 8
scl: 7
scan: true
# PCA9554 GPIO extender for display reset
pca9554:
- id: p_c_a
address: 0x20
i2c_id: i2c_bus
# Backlight PWM output and light component
output:
# Backlight LED
- platform: ledc
pin: GPIO06
frequency: 2000Hz
channel: 0
light:
- platform: monochromatic
output: GPIO06
name: Display Backlight
restore_mode: ALWAYS_ON
gamma_correct: 1
#spi:
# id: display_qspi
# type: quad
# clk_pin: 5
spi:
clk_pin: GPIO05
mosi_pin: GPIO01
miso_pin: GPIO02
display:
model: st7796
spi_id: display_spi
cs_pin:
pca9554: p_c_a
number: 2
dc_pin: 3
reset_pin:
pca9554: p_c_a
number: 1
rotation: 90
spi_mode: 1
color_order: bgr
pixel_mode: 16bit
#display:
# model: ST7796
# dc_pin: GPIO03
# #data_rate: 40MHz
# dimensions:
# height: 320
# width: 480
# transform:
# mirror_x: false
# mirror_y: false
# cs_pin:
# number: -1
# rotation: 0
# init_sequence:
touchscreen:
platform: ft63x6
transform:
swap_xy: true
mirror_x: false
mirror_y: true
on_touch:
- lambda: |-
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
### HA sensors
time:
- platform: homeassistant
timezone: Europe/Stockholm
entity_id: sensor.utegivare_temperature
lvgl:
widgets:
- label:
align: CENTER
