How to wire CCS811 and HDC1080 with ESPHome
I bought a TVOC and CO2 sensor on AliExpress and I tried to configure it with ESPhome, like this.
The problem is: it doesn’t do anything. I’d like to read the TVOC and CO2, and if possible the temperature and humidity. I connected the SDA to D0 and SCL to D1. The VCC to a 3V and the GND to a GND. I also tried not connecting the VCC. Right now I have a AM2302 connected to the same ESP and that is working.
Could someone tell me how to wire up the CCS811 and HDC1080 to get the four readings? And maybe share their configuration. Below is my config:
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: ####
  password: ####
  ap:
    ssid: "Slaapkameresp Fallback Hotspot"
    password: ####
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
i2c:
  sda: D0
  scl: D1
  scan: true
  - platform: dht
    pin: D2
    temperature:
      name: "Slaapkamer temperatuur"
    humidity:
      name: "Slaapkamer luchtvochtigheid"
    update_interval: 60s
    model: AM2302
  - platform: adc
    pin: A0
    name: "Slaapkamer lichtniveau"
    unit_of_measurement: lx
    filters:
      - lambda: |-
          return (x / 10000.0) * 2000000.0;
  - platform: ccs811
    eco2:
      name: "eCO2 Slaapkamer"
    tvoc:
      name: "TVOC Slaapkamer"
#    address: 0x5A
Did you try to put the WAK on GND?
Hi @MattTheBrofessor were you able to connect the ccs811 sensor? I’m having the same issue
