How tot Play local audio file mp3/anything to local pi audio output port.
just install mpd if not installed already then add mpd to your config file.
I don’t think this can be done on HASSIO
There is a mopidy hassio addon from bestlibre witch is a mpd alternative. https://github.com/bestlibre/hassio-addons
Hello, i already installed mpd but i read here there is only example to play playlist. Is there any way to play local file? Thanks
i just add them to a playlist file then trigger the playlist.
could you please tell me more how to “add them to playlist file then trigger the playlist”? Thanks
You don’t have to add it to playlist, simply use “music” as media_content_type.
