How use Shelly Flood MQTT wihtout lose the Cloud
How transform the Report as GET from Shelly flood to mqtt, and maintain Shelly Cloud without enable MQTT into Shelly flood
  1. First set Shelly flood with the Url of your Node-red Server In my case http://192.168.1.32:1880/sensor
    2)Create a webservice in Node-red that broadcast the body as mqtt payload
    3)Set for e.g Home Assistant sensor
That’s it
Enjoy
Sandro
at the moment the only way to use the shelly without loose the cloud connectivity is to use the custom component shelly for hass at https://github.com/StyraHem/ShellyForHASS
Nice I didn’t know you could do this, very cool.
Is hassIO required? I’m running Hass and HACS only.
Yes on hacs search for ShellyForHass and install it
Thanks very much, I’ll try installing using HACS :slight_smile:
Have you tried the mqtt explorer program? I found it easier to use then setting up HACS.
