How would I configure Blink integration from configuration.yaml or a script?
I currently have a home assistant using the ghcr.io/home-assistant/home-assistant:stable image. I then use a configuration.yaml to config the instance and mount that using a docker mount.
For my alexa integration I have the following…
alexa:
  smart_home:
    locale: en-US
    endpoint: https://api.amazonalexa.com/v3/events
    client_id: ...
    client_secret: ...
This works great so now I would like to do something like this for the Blink integration. I have looked here but this is done manually through the UI. How would I do this same thing with the configuration.yaml for Blink?
Like I see this in the core.config_entries but how do I make that into something I can copy up to the image and not check in sensitive data (like use secrets for the password etc)
        "entry_id": "1b4363e7c5609a26304abdfd68d2b4c0",
        "version": 3,
        "domain": "blink",
        "title": "blink",
        "data": {
          "username": "...",
          "password": "...",
          "device_id": "Home Assistant",
          "uid": "BlinkCamera_...",
          "token": "...",
          "host": "u053.immedia-semi.com",
          "region_id": "u053",
          "client_id": ...,
          "account_id": ...
        "options": {
          "scan_interval": 300
        "pref_disable_new_entities": false,
        "pref_disable_polling": false,
        "source": "user",
        "unique_id": "...email...",
        "disabled_by": null
