I have Google Calendar app running, but now I’ve added a new one in Google. But this one is not showing up, I thought this is done automatically?
KR,
Ch.
KR,
Ch.
Reload the Google Calendar integration, then check the file at /config/google_calendars.yaml
. You should be able to find it in there, but with track: false
. Change that last setting to true, then roload the integration again.
One way is to add your second Google calendar to be shared (view/edit) in your first calendar. That is what I have done with my professional Google Calendar and it shows as an entity in HA.
In my /homeassistant/config
directory, there is no file google_calendars.yaml
I do already have 10 different calendars showing up correctly, I would like to add #11
OK, now after a restart of HA the calendar shows up. Very strange, because I did it already yesterday.
Thanks for you support!
Christof
I can’t find the config file either, have looked everywhere and I am pulling my hair out trying to work out how to remove deleted calendars and add new ones. Perhaps I need to remove the integration entirely and just re add it.
Restarting everything hasn’t helped.
Remember, when re-installing a Google Integration, to remove the existing Application Credentials in HA
