I am still with my component ‘rollershutter’.
It does not seem to be loading.
To test, I want to generate logging output in init.py.
To understand the loading I have added log functions to the ethernet component in my git an use this own component.
In the ethernet_component.cpp the log outputs are displayed
[19:26:52][C][ethernet:325]: Ethernet:
[19:26:52][C][ethernet:514]: Hallo <<<<===
[19:26:52][C][ethernet:515]: IP Address: 192.168.xxx.xxx
[19:26:52][C][ethernet:516]: Hostname: 'roller-shutter-2'
[19:26:52][C][ethernet:517]: Subnet: 255.255.255.0
in the ‘init.py ’ i have add 2 lines
line 45 LOGGER = logging.getLogger(__name__)
line 277 async def to_code(config):
line 278 LOGGER.debug("to_code ethernet Start") <<<<===
line 279 var = cg.new_Pvariable(config[CONF_ID])
However, I do not see the log outputs from the init.py of the ethernet component anywhere.
Where can I see these log outputs?
Best regards Mario
