Howto install SPC Web Gateway on HasOS
How can you install the ‘SPC Web Gateway’ on the same RPi which is running HA OS 6.5? Running it on a separate RPi while running HA already on a RPi4 seems a little bit overdone. I guess you need a Docker container to do this but I could not find a ‘howto’ about this.
Any ideas??
Any solution on this yet? I have tried several solution without any luck.
