HowTo: Integrating a Swentibold EuroAir Ventilation with Homeassistant
This article shall describe how to establish a modbus connection to an EuroAir Ventilation System and integrate it into Homeassistant.
I have a EuroAir350 bought in 2024 at my home and the config is tested to work with this modell.
First I bought a Waveshare TCP to Modbus adapter and connected it to the Webcontroller Clamps on the EuroAir Unit (A-A,B-B, GND-GND), as shown in this picture provided to me (via email) by EuroAir.
This video(youtube . com/watch?v=Xuj2YFZ5zME&t=96s&pp=ygUQd2F2ZXNoYXJlIG1vZGJ1cw%3D%3D) goes into detail, on how to configure the Waveshare Modbus adapter, but basically you have to switch on the waveshare modul, and download the configuration software(Vircom)
After that you can configure the following modbus settings in the Vircom software:
9600 baud
8 data bits
No parity
1 stop bit
Integrating it into HomeAssistant
I could not find the correct slaveID anywhere in the documentation, but the company mentioned via Email it’s 10.
modbus:
- name: "lüftung"
  type: tcp
  host: <waveshare ip>
  port: 502
  sensors:
    - name: "Lüftung-Außenluft"
      slave: 10
      address: 4
      input_type: input
      data_type: uint16
      scale: 0.1
      precision: 1
      unit_of_measurement: "°C"
      unique_id: central_lueftung.temp_aussenluft
    - name: "Lüftung-Raumluft"
      slave: 10
      address: 5
      input_type: input
      data_type: uint16
      scale: 0.1
      precision: 1
    - name: "Lüftungstufe"
      address: 42
      input_type: holding
      data_type: uint16
      slave: 10
  switches:
    - name: "Lüftung An/Aus"
      address: 1
      command_on: 1
      command_off: 0
      write_type: holding
      slave: 10
      verify:
          input_type: holding
          address: 1
          state_on: 1
          state_off: 0
    - name: "Lüftung ByPass Offen/Geschlossen"
      address: 31
      command_on: 1
      command_off: 0
      write_type: holding
      slave: 10
      verify:
          input_type: holding
          address: 31
          state_on: 1
          state_off: 0
This Config allows you to e.g. activate the bypass using homeassitant and control the ventilation speed. I will update this post, with a full list of values and maybe even create a custom integration for the EuroAir units.
Here is the download link for vircom: https://www.waveshare.com/wiki/RS485_TO_ETH_(B)#Software_Installation) and a screenshot of the result
Hi @ludik0 any progeress on this one?
I got a similar machine. Do you have a full list of Modbus registers? The list i found in the manual seems to be different, because the addresses you used do not match the ones i found in the documentation. https://www.swentibold.com/_files/ugd/cab2d0_dc6cb579ece84272b592bbadf732ffce.pdf (https://www.swentibold.com/wtwtoestellen?lang=de)
Hi @kamil02
I have EuroAir 350,
but I decide to simplify connectivity to device using MAX485 (TTL to RS485 Module) and ESP32, after contacting swentibold, they send me quite old but more correct list of registers together with other modbus important information:
10.02 Swentibold - modbus v1_25_H.pdf
so just contact swentibold regarding your device if those registers didn’t match for you.
esphome relevant configuration that was defined as result of provided documentation that could be useful:
# UART for Modbus
uart:
  tx_pin: GPIO17 # Connects to DI on MAX485
  rx_pin: GPIO16 # Connects to RO on MAX485
  baud_rate: 9600
  stop_bits: 1
  parity: NONE
# Modbus
modbus:
  uart_id: uart_modbus
  flow_control_pin: GPIO21 # This single pin MUST be connected to both DE and RE on the MAX485
  send_wait_time: 250ms
# Define the Swentibold ventilation unit as a Modbus controller target
modbus_controller:
  - id: swentibold_wtw
    address: 10            # Slave ID
    modbus_id: modbus_hub
    update_interval: 10s
#  # Register 25: Low Speed Hours
#  - platform: modbus_controller
#    modbus_controller_id: swentibold_wtw
#    name: "Low Speed Hours"
#    address: 25
#    register_type: holding
#    unit_of_measurement: "h"
#    icon: "mdi:clock-outline"
#  # Register 26: Medium Speed Hours
#    name: "Medium Speed Hours"
#    address: 26
#  # Register 27: High Speed Hours
#    name: "High Speed Hours"
#    address: 27
#    name: "Bypass temp test"
#    address: 2
#    unit_of_measurement: "°C"
#    filters:
#      - multiply: 0.1
  # Register 28: Filter Hours
    address: 28
    icon: "mdi:air-filter"
#  # Register 46: Cooling Percentage
#    name: "Cooling Percentage"
#    address: 46
#    unit_of_measurement: "%"
#    icon: "mdi:coolant-temperature"
#  # Register 47: Heating Percentage
#    name: "Heating Percentage"
#    address: 47
#    icon: "mdi:radiator"
  # Internal sensor for device type (used by text_sensor below)
    internal: true
    address: 0 # Register 0: Type
text_sensor:
  # Register 0: Device Type
    icon: "mdi:information-outline"
    lambda: |-
      auto val = id(wtw_type_raw).state;
      if (isnan(val)) { return {"Unknown"}; }
      switch ((int)val) {
        case 1: return {"Basis"};
        case 2: return {"Bypass"};
        case 3: return {"Comfort"};
        default: return {"Unknown"};
binary_sensor:
  # Register 29: Status (bit-mapped)
  # Bit 1 = Medium vent active
    name: "Medium Ventilation"
    address: 29
    bitmask: 0b0000000000000010 # (1 << 1)
    icon: "mdi:fan-speed-2"
  # Bit 2 = High vent active
    name: "High Ventilation"
    address: 29
    bitmask: 0b0000000000000100 # (1 << 2)
    icon: "mdi:fan-speed-3"
  # Register 30: Digin (Digital Inputs, bit-mapped)
  # Bit 2 = Hygrostat
    address: 30
    bitmask: 0b0000000000001000 # (1 << 3)
    icon: "mdi:water-percent"
#  # Register 43: Recirculation status
#    name: "Recirculation Status"
#    address: 43
#    device_class: opening
#  # Register 44: Cooling status
#    name: "Cooling Status"
#    address: 44
#    device_class: running
#  # Register 45: Heating status
#    name: "Heating Status"
#    address: 45
#    device_class: heat
#  # Register 40: Error status bits
#  # You can add one for each bit you want to monitor
#    name: "Fault E1"
#    address: 40
#    bitmask: 2
#    device_class: problem
#    name: "Fault Ft"
#    address: 40
#    bitmask: 256
select:
  # Register 1: On/Off
    address: 1
    optionsmap:
      "Off": 0
      "On": 1
    icon: "mdi:power"
  # Register 8: Filter time reset
    name: "Filter Time Reset"
    address: 8
    optionsmap:
      "No": 0
      "Yes": 1
    icon: "mdi:filter-remove-outline"
  # Register 23: Summer/Winter Time
    name: "Automatic Summer/Winter Time"
    address: 23
    optionsmap:
      "Disabled": 0
      "Enabled": 1
    icon: "mdi:calendar-sync"
  # Register 24: Holiday Mode
    address: 24
    optionsmap:
      "Disabled": 0
      "Enabled": 1
    icon: "mdi:palm-tree"
  # Register 31: Bypass
    address: 31
    optionsmap:
      "Closed": 0
      "Open": 1
    icon: "mdi:swap-horizontal"
  # Register 32: Earth cooling
    address: 32
    optionsmap:
      "Closed": 0
      "Open": 1
    icon: "mdi:earth-arrow-right"
  # Register 42: Ventilation Mode
    address: 42
    optionsmap:
      "Auto": 0
      "Low": 1
      "Medium": 2
      "High": 3
    icon: "mdi:fan"
switch:
  - platform: restart
number:
  # Register 2: Bypass Temperature Setpoint
  # Probably FW issue - value * 10 (e.g. 150: 15°C)
    name: "Bypass Temperature Setpoint"
    address: 2
    mode: slider
    step: 10
    min_value: 150
    max_value: 300
    icon: "mdi:thermometer"
  # Register 3: Recirculation temperature
    name: "Recirculation Temperature Setpoint"
    address: 3
    mode: slider
    step: 1
    min_value: -10
    max_value: 30
  # Register 4: Comfort Temperature Setpoint
    name: "Comfort Temperature Setpoint"
    address: 4
    mode: slider
    step: 1
    min_value: 15
    max_value: 30
    icon: "mdi:home-thermometer-outline"
  # Register 5: Hygrostat Switch-On Delay
    name: "Hygrostat Switch-On Delay"
    address: 5
    unit_of_measurement: "m"
    mode: slider
    step: 1
    min_value: 0
    max_value: 120
    icon: "mdi:timer-plus-outline"
  # Register 6: Hygrostat Switch-Off Delay
    name: "Hygrostat Switch-Off Delay"
    address: 6
    mode: slider
    step: 1
    min_value: 0
    max_value: 120
    icon: "mdi:timer-minus-outline"
  # Register 7: Filter Change Interval
    name: "Filter Change Interval"
    address: 7
    unit_of_measurement: "w"
    mode: slider
    step: 1
    min_value: 1
    max_value: 99
    icon: "mdi:calendar-clock"
* some registers are commented just because they have no affect in my case
Hope that will help others to make their ventilation system more smarter :beers:
That actually helped quite a bit. Looks like the registers didnt change in 13 years :grin:. For now I am able to control the ventilation speed and see some sensor data. Didn’t check all the registers, yet. This is a good starting point for now.
I also got the EuroAir 350 and I am also using the Waveshare adapter.
The only problem I had so far was that one needs to be in the same VLAN as the adapter to be able to change its IP Mode to DHCP. You got to change that with the mentioned VirCom software.
