Is it possible to make multiple state changes, that follow briefly after each other, ‘transform’ into 1 if within a certain timeframe?
I assume this can be done with a template but cannot find out how.
TIA
TIA
There’s a throttle option in the Filter integration if it’s a numeric value.
Hi Didgeridrew, thanks for helping!
Sorry, I should have shared this right away:
Apparently, none of those seem to usable with the filter integration.
For the binary sensor you could use a state-based template binary sensor with delay_on
and/or delay_off
to throttle the state changes.
For the Frigate-based sensor, what are you currently getting and what do you want?
It’s a KNX binary sensor which does not seem to have that option…
For Frigate, I’m trying out the different sensors but maybe I have to read the Frigate documentation once more…
I was using the Person sensor but this would trigger multiple times within a short timeframe.
I’m using this to activate the screen on an Android tablet & reload the HA app wo when the doorbell is pushed the app navigates to another dashboard with a live stream from the doorbell & some control buttons.
Maybe you can use a trigger based template sensor instead with knx.telegram
trigger. Or just use the trigger in your automation directly instead of a binary sensor… if it’s a doorbell, it probably doesn’t have a state anyway.
