I’m searching and searching, but can’t find a solution.
Issue: I want to use HTML5 Notifaction Actions, but HA won’t register them
Solution: It seems that NGINX block the events, according to https://www.home-assistant.io/integrations/html5/#making-notifications-work-with-nginx-proxy
My Setup:
I’m using the DuckDNS addon with Let’s encrypt certificates. I’m able to reach the HA with SSL.
Approaches:
I’ve installed the NGINX Plugin, deleted the http-info in configuration.yaml but with this setup, I was not able to reach HA on HTTPS.
I’m trying to figure out, where I have to place the information from https://www.home-assistant.io/integrations/html5/#making-notifications-work-with-nginx-proxy
Can anybody help please?
