michel72
(Michel - espthings.io)
1
I am trying to http post values of the esphome dsmr sensors from the esphome node into an external API
- The API expects all 3 values to be posted at once:
- All values need to be multiplied by 10.
curl -X 'POST' \
'http://192.168.100.100/currents?L1=60&L2=70&L3=80' \
-H 'accept: application/json' \
-H 'Content-Type: application/json' \
-d '{}'
The values from esphome (DSMR) I am trying to post:
- platform: dsmr
current_l1:
name: "$human_devicename - Current Phase 1"
current_l2:
name: "$human_devicename - Current Phase 2"
current_l3:
name: "$human_devicename - Current Phase 3"
I would like to post all 3 values into the API at once on any change of any of the 3 DSMR sensors.
What would be the best way to do that?
Cheers,
Michel
michel72
2
I have been trying a few options:
- platform: dsmr
current_l1:
on_value:
then:
- http_request.post:
verify_ssl: false
url: http://192.168.207.121/currents?
json: |-
root["L1"] = id(current_l1).state;
root["L2"] = id(current_l2).state;
root["L3"] = id(current_l3).state;
Which results in:
INFO Generating C++ source…
ERROR Circular dependency detected! Please run with -v option to see what functions failed to complete.
Then I tried:
- platform: dsmr
current_l1:
current_l2:
current_l3:
time:
- platform: sntp
on_time:
- seconds: 5
then:
verify_ssl: false
json: |-
Which compiles, but does not return the correct data.
Then I tried:
time:
- platform: sntp
on_time:
- seconds: 5
then:
verify_ssl: false
url: !lambda |-
return ((std::string) "http://192.168.207.121/currents?L1=" + id(current_l1).state).c_str() + "&L2=" + id(current_l2).state).c_str() + "&L3=" + id(current_l3).state).c_str();
which returns:
/config/esphome/slimmelezer.yaml:261:67: error: no match for ‘operator+’ (operand types are ‘std::string’ {aka ‘std::__cxx11::basic_string’} and ‘float’)
261 | return ((std::string) “http://192.168.207.121/currents?L1=” + id(current_l1).state).c_str() + “&L2=” + id(current_l2).state).c_str() + “&L3=” + id(current_l3).state).c_str();
/config/esphome/slimmelezer.yaml:261:124: error: expected ‘;’ before ‘)’ token
/config/esphome/slimmelezer.yaml:261:124: error: expected primary-expression before ‘)’ token
*** [/data/slimmelezer/.pioenvs/slimmelezer/src/main.cpp.o] Error 1
========================== [FAILED] Took 2.52 seconds ==========================
I obviously need some guidance
