HTTP push switch like sensor
Hi All,
First of all I am new here, so sorry if I posted in the wrong section or if it had has been already asked.
I was playing around with pushing sensor data via the /api/state/sensor.xxxx
Which I got to work perfectly.
Basically this adds a sensor in exactly the way I want.
The question now is can I use the same method to add a switch.
Pushing a switch does add it on the overview but it does not give it a toggle button.
Adding one switch in the config file and then pushing a switch does present a new switch with toggle button (Maybe this is a bug?).
However when pressing this toggle button nothing happens on the receiving server.
The home assistant log and website do show that an action has been taken.
Am I doing something wrong or am I trying to do something which is not possible (at the moment or ever)
Regards,
vpolder
