Https: Unable to connect to Home Assistant. HTTP works finde
fresh install hassio on a debian10.
  1. installed, config and start duck dns, all went well i think
  2. added:
 http:
   base_url: XXX.duckdns.org:8123
   ssl_certificate: /ssl/fullchain.pem
   ssl_key: /ssl/privkey.pem
to my configuration.yaml
restart.
http://xxx.duckdns.org:8123 works, but unencrypted
https://xxx.duckdns.org:8123 IS encrypted and loads a page BUT im only getting the message: Unable to connect to Home Assistant.
what did i do wrong?
Failed to post your logs?
hass logs
20-01-24 14:16:57 INFO (MainThread) [hassio.host.control] Initialize host reboot over systemd
20-01-24 14:16:57 INFO (MainThread) [hassio.addons] Phase 'application' stop 1 add-ons
20-01-24 14:16:57 INFO (SyncWorker_2) [hassio.docker.interface] Stop addon_core_configurator application
20-01-24 14:16:57 INFO (SyncWorker_2) [hassio.docker.interface] Clean addon_core_configurator application
20-01-24 14:16:57 INFO (SyncWorker_9) [hassio.docker.interface] Stop homeassistant application
20-01-24 14:17:58 INFO (MainThread) [hassio.addons] Phase 'services' stop 1 add-ons
20-01-24 14:17:58 INFO (SyncWorker_13) [hassio.docker.interface] Stop addon_core_duckdns application
20-01-24 14:17:58 INFO (SyncWorker_13) [hassio.docker.interface] Clean addon_core_duckdns application
20-01-24 14:17:58 INFO (MainThread) [hassio.addons] Phase 'system' stop 0 add-ons
20-01-24 14:17:58 INFO (MainThread) [hassio.addons] Phase 'initialize' stop 0 add-ons
20-01-24 14:17:58 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.Reboot on /org/freedesktop/systemd1
20-01-24 14:19:02 INFO (MainThread) [__main__] Initialize Hass.io setup
20-01-24 14:19:02 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 195
20-01-24 14:19:02 INFO (MainThread) [__main__] Setup HassIO
20-01-24 14:19:02 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-01-24 14:19:02 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-01-24 14:19:02 WARNING (MainThread) [hassio.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-01-24 14:19:02 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-01-24 14:19:02 INFO (MainThread) [hassio.host.info] Update local host information
20-01-24 14:19:02 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-01-24 14:19:02 INFO (MainThread) [hassio.host.services] Update service information
20-01-24 14:19:02 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-01-24 14:19:02 INFO (MainThread) [hassio.host.network] Update local network DNS information
20-01-24 14:19:02 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-01-24 14:19:02 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-01-24 14:19:02 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
20-01-24 14:19:02 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-01-24 14:19:02 INFO (SyncWorker_2) [hassio.docker.interface] Attach to homeassistant/amd64-hassio-dns with version 1
20-01-24 14:19:02 INFO (MainThread) [hassio.dns] Start CoreDNS plugin
20-01-24 14:19:02 INFO (MainThread) [hassio.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-01-24 14:19:02 INFO (SyncWorker_4) [hassio.docker.interface] Clean hassio_dns application
20-01-24 14:19:03 INFO (SyncWorker_4) [hassio.docker.dns] Start DNS homeassistant/amd64-hassio-dns with version 1 - 172.30.32.3
20-01-24 14:19:03 INFO (SyncWorker_5) [hassio.docker.interface] Attach to homeassistant/qemux86-64-homeassistant with version 0.104.3
20-01-24 14:19:03 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
20-01-24 14:19:03 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-01-24 14:19:03 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 63 new - 0 remove
20-01-24 14:19:03 INFO (MainThread) [hassio.addons] Found 2 installed add-ons
20-01-24 14:19:03 INFO (SyncWorker_3) [hassio.docker.interface] Attach to homeassistant/amd64-addon-duckdns with version 1.10
20-01-24 14:19:03 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/amd64-addon-configurator with version 4.2
20-01-24 14:19:03 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-01-24 14:19:03 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
20-01-24 14:19:03 INFO (MainThread) [hassio.discovery] Load 0 messages
20-01-24 14:19:03 INFO (MainThread) [hassio.ingress] Load 0 ingress session
20-01-24 14:19:03 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 1
20-01-24 14:19:03 INFO (MainThread) [__main__] Run Hass.io
20-01-24 14:19:03 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
20-01-24 14:19:03 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
20-01-24 14:19:03 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
20-01-24 14:19:03 INFO (MainThread) [hassio.addons] Phase 'services' start 1 add-ons
20-01-24 14:19:04 INFO (SyncWorker_8) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-duckdns with version 1.10
20-01-24 14:19:09 INFO (SyncWorker_10) [hassio.docker.interface] Start homeassistant/qemux86-64-homeassistant
duck dns logs
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[15:19:06] INFO: OK
93.193.79.130
NOCHANGE
Processing xxx.duckdns.org
 + Checking domain name(s) of existing cert... unchanged.
 + Checking expire date of existing cert...
 + Valid till Apr 20 23:32:42 2020 GMT Certificate will not expire
(Longer than 30 days). Skipping renew!
so… no one? :frowning:
Clear your cache, and look for browser errors (F12 I believe)
