Hi , I’m using SUN2000 (8KTL-M1) mit 10kWh LUNA (also 2 Packs) + Smartmeter DTSU 666 + SDonge. I have all integratet with “HUAWEI Solar” from HACS via TCP Modbus.
Everything works perfect until I have installed a Huawei Wallbox.
Looks like there are to many Clients connecting to the modbus / SDongle.-> lost connectin from HA to Huawei
A Modbus Proxy seams not to be the solution, because I can’t set the proxy IP in the Wallbox.
Is there anyone who has the same Installation and managed it to have a stable Integration to Home Assistant
I’m using fusion solar and wanted to install HACS Huawei modbus without success.
Always got failed integration.
Later on I tried to access some mdobus registers with the pure modbus integration. And it worked at least after setting up timeouts and repeats.
So for sure the SDongle response behaviour can influence the bahaviour heavily (maybe cause by #clients, generell lan setup, …)
modbus:
- name: huawei_sun2000
type: tcp
host: 192.xxx
port: 502
delay: 2 # nach Verbindungsaufbau 2 s warten
timeout: 5 # bis zu 5 s auf Antwort warten
message_wait_milliseconds: 2500 # 250 ms zwischen Requests
retries: 3 # WICHTIG: keine 3 schnellen Wiederholungen
# retry_on_empty: true
sensors:
- name: "Huawei AC Ladeabschalt-SOC"
slave: 1
address: 47088
input_type: holding
data_type: uint16
scale: 0.1
precision: 1
unit_of_measurement: "%"
scan_interval: 60 # alle 60 s reicht völlig
- name: "Huawei Energy Working Mode"
slave: 1
address: 47086
input_type: holding
data_type: uint16
scan_interval: 60
