Same here and no clue yet, what might the cause. The setup simple fails nothing more.
Does anyone have an idea?
I have the dongle (no inverter cascade or battery) and want to use Modbus TCP.
Firmware:
Dongle V200R022C10SPC312
Inverter V100R001C00SPC173
HA OS 2026.1.0 but the same with the latest from 2025
HA runs on Proxmox
WR setting: Modbus TCP: unrestricted
Ports tried: 502, 6607 (but found 502 the only one open, so…)
Ids tried: 1,2,16,100, AUTO (suspect it is ID 2 in my case)
I have no installer rights in fusion solar but access the devices locally.
So where can I see the ID exactly?
2026-01-08 22:46:51.858 ERROR (MainThread) [custom_components.huawei_solar.config_flow] Unexpected exception while connecting via ModbusTCP
File "/config/custom_components/huawei_solar/config_flow.py", line 537, in async_step_setup_network
info = await validate_network_setup(
...<4 lines>...
File "/config/custom_components/huawei_solar/config_flow.py", line 205, in validate_network_setup
bridge = await create_tcp_bridge(
...<3 lines>...
File "/usr/local/lib/python3.13/site-packages/huawei_solar/bridge.py", line 693, in create_tcp_bridge
return await _create(await AsyncHuaweiSolar.create(host, port, slave_id), slave_id)
File "/usr/local/lib/python3.13/site-packages/huawei_solar/bridge.py", line 726, in _create
model_name_result = await client.get(rn.MODEL_NAME, slave_id)
File "/usr/local/lib/python3.13/site-packages/huawei_solar/huawei_solar.py", line 261, in get
return (await self.get_multiple([name], slave_id))[0]
File "/usr/local/lib/python3.13/site-packages/huawei_solar/huawei_solar.py", line 305, in get_multiple
response = await self._read_registers(
...<3 lines>...
File "/usr/local/lib/python3.13/site-packages/huawei_solar/huawei_solar.py", line 442, in _read_registers
return await _do_read()
File "/usr/local/lib/python3.13/site-packages/backoff/_async.py", line 151, in retry
ret = await target(*args, **kwargs)
File "/usr/local/lib/python3.13/site-packages/huawei_solar/huawei_solar.py", line 389, in _do_read
response = await self._client.read_holding_registers(
...<3 lines>...
File "/usr/local/lib/python3.13/site-packages/pymodbus/transaction/transaction.py", line 201, in execute
raise ModbusIOException(txt)
pymodbus.exceptions.ModbusIOException: Modbus Error: [Input/Output] No response received after 3 retries, continue with next reques
As I am pretty much a novice to this, does anyone have an idea what’s going on?
Thanks,
HANT
