Hubitat Status not Updating HA
Anyone have any issues getting homeassistant to update sensors correctly from Hubitat? I use hubitat for my zwave and zigbee bridge…
I can push commands and it will do what I say and I can manually reload the integration and get updated statuses but sometimes lights and or contact sensors will not update correctly unless forced to update.
Example… I manually switch a light on or open a cover homeassistant may not get an updated status. If I have scripts tied to this scripts will not run because they get no status.
Did you ever figure it out? I’m having the same issue and my guess is that I have some extremely simple oversight.
@hanselljl nope… sometimes you have to manually force it via HA to get it ot start updating status right. If you do a reset until you use the switches the status may be wrong
