Hubspace integration Question
Does anyone have experience with adding devices to a Hubspace integration.
I am new to Home assistant and successfully added the Hubspace integration to my system. I can see and interact to the devices through with Hubspace integration with HA.
I added two new subspace switches and I see them in the Hubspace portal, I can also interact with them through Alexa. I haven’t seen them show up in HA under entities. Is there a delay before the integration sees these devices? Is there something I can do to force the integration to refresh its entity list? Any suggestions are appreciated.
Bill
I found a work around. I went to the HACS tab on my HA instance and found the Hubspace-HomeAssistant entry. Selected Redownload. This operation made the missing switch visible. I did find an entry in the log that looked like it was related to this issue. Unfortunately I was thinking about troubleshooting and cleared the error. I will try to duplicate the issue and post the log entry.
Bill
