Last night I noticed that one of my Philips Hue bulbs was offline. I am new to Home Assistant, so I proceeded to remove this bulb from HA and tried to re-add. Steps I took:
Ran zha.remove service with the ieee as a parameter. This successfully removed the bulb from the front end.
Ran zha.permit and tried to re-add bulb via Configuration > ZHA > Add Devices – nothing was recognized
Turned the bulb on and off 10 times
Reviewed zigbee.db – no rows in any of the tables had any record of the bulb I removed (this is good, right?)
Review every file in .storage directory. I did find a record zha.storage. When I delete the bulb from this and restart HA, the removed bulb reappears in this file – is this a problem?
Did not see removed bulb in any other file in the .storage and .homeassistant directory except as noted above
My setup: RPi3+, Hassbian, husbzb-1 (Zigbee & Zwave controller). I do NOT have a Hue hub.
Any thoughts?
Edit: Turned on debugging. When I turn on the light, I get this:
2019-08-30 11:58:28 DEBUG (MainThread) [bellows.zigbee.application] Received incomingMessageHandler frame with [<EmberIncomingMessageType.INCOMING_BROADCAST: 4>, <EmberApsFrame profileId=0 clusterId=19 sourceEndpoint=0 destinationEndpoint=0 options=8 groupId=0 sequence=35>, 255, -44, 0x7511, 255, 255, b' *redacted ieee value i have chosen to not copy/paste* ']
2019-08-30 11:58:28 DEBUG (MainThread) [bellows.zigbee.application] No such device 0x7511
