Hue Bulbs - Entity not available after upgrade to 102.3
I had just upgraded to the latest available build last night, and got everything working.
This morning, I saw that there was a small incremental upgrade (0.102.3), so I applied it.
Now it seems that my hue lights are all showing up as “entity not available”. I do show the hue sensors (temp, motion, lux) as well as the hue dimmer switches via the custom_component.
Unless anyone else has seen this and has an easy fix, I’m probably going to remove the hue integration and re-add it. I’m just nervous to do that as I have the hue bulb entities included in a lot of NodeRed flows, and if the entity id’s change, it’s going to create a lot of work!
same for me. is there a solution ?
