Hue Dimmer Switch suddenly not working?
RWL020, been working for years and suddenly not. I’m using Z2M, I’ve done both the four-button reset and held the reset pin down for 10s+ multiple times. It seems to pair, but all the states just show as “Unknown”. I rename it the same thing and it’s even still paired to my remote BP that I have been using literally for years. And yes it has a brand new battery and the status LED shows when resetting/pairing, but not when I click the buttons.
I’m not sure how to actually read logs for stuff, but the Z2M webui shows last seen N/A after pairing.
I recently moved from ZHA to Z2M, and had the same frustration with one of those Hue Dimmers (v2).
I added a step to remove the battery for a minute after resetting the dimmer (before re-pairing). Not sure if it was after the 4 button or pin reset. It’s all rather a blur. I had given up for an hour, but returning to it to try resetting and removing the battery, it surprisingly paired.
I can’t believe that worked!
  1. Held four buttons until LED
  2. Held reset pin until LED
  3. Remove battery
    3a. Lose screw (optional)
  4. Reinstall battery
  5. Force delete old device from Z2M
  6. Permit join all
