A couple of things have changed with hue recently - From your main page, click configuration in the sidebar, then click integrations and see what’s there.
Might be worth as you say removing everything referencing hue and letting discovery try and add it again
Im far from an expert in HA but not a novice either but I’m not sure what to make of that error…might need someone who knows a little more to chip in here…
I did take the custom_components/hue.py out and indeed the now native Hassio Hue component seems to operate as desired, showing and switching the lights.
Unfortunately @robmarkcole 's CC/sensor/hue.py stopped working. All sensors are there in the frontend, but show Unknown…
If this is really independent of the Hue in Hassio, how could this be? Only took out the hue: in configuration.yaml, should that g back after all @robmarkcole? Hope the (hassio) hue.py shouldn’t be restored…
this is the only error in the log now:
8-04-27 21:10:35 ERROR (MainThread) [homeassistant.components.light.hue] Unable to reach bridge [ip_address]
ip_address is correct and reachable… I can see and switch the lights, both through Hassio now, and my app.
no sensor is being created anymore by the CC, cant find them in the dev-tools
Please check you have the latest version of the component from GitHub. It’s just a REST sensor so shouldn’t be affected by any changes to the Hue hub component
am also having the same issue. I added the hue: in configuration.yaml. HA shows the card to configure the bridge. I press the button on the Hue bridge but nothing happens, what can i do?
The same issue here. I can see the HUE in menu - settings - Integrations - discovery - hue. Then when I press config, it wants to press the button on HUE bridge. I press the button but nothing happens. It says " Failed to register, please try again"
