Hue Effects: is there a way to call an effect from HA?
I have several Effects set up on the Hue Bridge. I can call them from the Hue Essentials app, but I’d like to be able to run them as buttons from the dashboard. I saw in the GitHub (https://github.com/home-assistant/core/pull/68567) that Effects are theoretically available, but I can’t find any documentation on how to structure the command.
Anyone got any pointers? Thanks in advance.
This may be of no help whatsoever as the only affects I use is ‘candle’ however these candle affects once added to the room do show up as a scene in HA and can therefore be called via HA.
I would really like to know this as well
