Hue lights rarely available
Hi everyone,
I’m fairly new to Home Assistant, but I think I’ve got most things under control except one:
I’m currently running Hassio on a RBP 4, with a few integrations and in particular the Philips Hue one. However, my lights are very often unavailable (see picture below):
My logs are getting spammed with:
2021-05-24 11:44:38 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Timeout fetching sensor data
2021-05-24 11:44:55 ERROR (MainThread) [homeassistant.components.hue.sensor_base] Timeout fetching sensor data
2021-05-24 11:44:55 ERROR (MainThread) [homeassistant.components.hue.light] Timeout fetching light data
I also have those lights in Smarthome and in the Hue app, and they are available there. I have tried changing the channel for the lights, reloading the integration, removing and adding the integration, resetting the Hue hub…
All my other integrations work with no problem. Has any one got an idea what I can do to sovle this, or at least troubleshoot?
Maybe stating the obvious, but it looks like a network issue between HA and your Hue Hub.
As it’s working on the Hue app, I assume the issue is on the HA side.
Maybe try to ping the hub from HassOS when your lights are unavailable…
