you are right.
How to do an automation that understands a double/triple/quadruple click? Is it possible?
you are right.
Not sure what I’m doing here but I can’t even get off the starting blocks! (Newbie).
Am I supposed to be able to install this into Hassio automatically?
I Have tried adding the git link https://github.com/robmarkcole/Hue-sensors-HASS but nothing appears to allow an install.
This is my log:
18-02-15 17:39:47 ERROR (MainThread) [hassio.addons] Can’t load from repository https://github.com/robmarkcole/
18-02-15 17:39:47 INFO (MainThread) [hassio.addons] Load addons: 19 all - 0 new - 0 remove
18-02-15 17:39:55 INFO (MainThread) [hassio.addons.git] Clone addon https://github.com/robmarkcole/Hue-sensors-HASS repository
18-02-15 17:39:57 WARNING (MainThread) [hassio.addons.data] Can’t read repository information from /data/addons/git/7c7e82cf/repository.json
18-02-15 17:39:57 INFO (MainThread) [hassio.addons] Load addons: 19 all - 0 new - 0 remove
18-02-15 17:43:13 WARNING (MainThread) [hassio.addons.data] Can’t read repository information from /data/addons/git/7c7e82cf/repository.json
18-02-15 17:43:13 INFO (MainThread) [hassio.addons] Load addons: 19 all - 0 new - 0 remove
Hi @Martin_Granger you need to setup the Samba share addon then place the folder custom_components in your config directory.
Cheers
@robmarkcole thank you for this add on, much faster and easier than set up using the rest sensor! But I have as many more lots of error messages “updating hue sensor took longer…” Has anyone had success with longer update intervals? how long can it be and still work fine with the remote switch dimmer?
And one more thing: I want to use something that tells me if the hue sensor is not updating for some hours, and use that to tell me something wrong with the sensor. Just used the last updated when I used rest sensor, but that does bot seem to work with this add-on. Is there a way of achieving this? Meaby some way to trigger if temperature or lux is changing?
okay - thanks for that. I already have samba installed and work on the files this way, just didn’t know if there was some sort of auto install thing going on.
I’ve now got it installed, so I’m sure I’ll have plenty of questions soon!
Many thanks for your hard work on this
I do seem to be having a bit of an oddity (probably not for this thread, but hey-ho)
I am setting up an automation with the motion sensor, but it only seems to be triggering one entity (the first in the list). I have tried swapping the entities around, and whichever is first works. Any ideas?
My automation code:
- id: '7'
alias: Hall motion on
- platform: state
entity_id: sensor.hall_motion_sensor
to: 'on'
- service: notify.pushbullet
message: 'Motion in the hall'
target: 'device/Google Pixel 2'
- service: light.turn_on
entity_id:
- light.hall_downstairs_ceiling_light
- light.hall_downstairs_big_lamp
- id: '8'
alias: Hall motion Off
- platform: state
to: 'off'
for:
minutes: 5
message: 'Motion Detected off'
- service: light.turn_off
entity_id:
First of all thank you for creating that fantastic component - extremely helpful.
I have realised two strange behaviours with template sensors on the attributes “battery” and “last updated” (hue dimmer switch):
Is this a known issue?
Thanks. For your points.
Cheers
Maybe there is something wrong with my configuration (sensor.living_room is the sensor which automatically appears from your component and corresponds to a hue dimmer switch)?
sensors:
hue_switch_living_room_battery:
friendly_name: 'Hue Switch Living Room Battery'
value_template: '{{ states.sensor.living_room.battery }}'
unit_of_measurement: '%'
sensors:
hue_switch_living_last_updated:
value_template: '{{ states.sensor.living_room.last_updated }}'
You are missing attributes. Should be something like states.sensor_name.attributes.last_updated
Oh sh**, sorry. I was looking over it and over it again but yes, this was the solution. thanks very much again
HI Robin,
Any thoughts on where to look for the Phone not showing it’s icon?. mdi:cellphone should be available…
Not sure which of the phone instances the components reads, but there’s several of them and i already have set icons and images in know_devices to show their instance ( iCloud, wifi, bluetooth etc) .
might that be it?
I believed this to be the sensor created by the custom component, and i have nothing set for that.
Cheers,
Marius
o really?? i was under the impression the icon was set in your custom component?? as with RWL and SML.
last 2 lines:
elif self._model == 'Geofence':
self._icon = 'mdi:cellphone'
Just in case it helps others: I had to add a delay between each device switching on. As it is lightwaverf gear, I think it may have been getting confused with more than one thing firing at the same time.
New code:
- id: '7'
- platform: state
to: 'on'
condition:
- condition: sun
after: sunrise
- condition: sun
before: sunset
- condition: state
entity_id: group.family
state: home
entity_id: light.hall_downstairs_ceiling_light
- delay: '00:00:01'
entity_id: light.hall_downstairs_big_lamp
- id: '8'
- platform: state
to: 'off'
for:
minutes: 20
condition:
- condition: state
state: home
- delay: '00:00:01'
HI Rob,
Had a chance to look at this?
another question: I just discovered that in /deps/lib/python3.6/sitepackages, there’s this folder:
containing an older file hue_sensors.py. Is this still necessary or can i safely delete the hue_sensors…egg-info and hue_sensors.py?
Thanks,
Marius
HI @Mariusthvdb haven’t looked at Hue as busy with other projects.
I think you can safely delete those files.
Cheers
Pardon me please if this has been answered elsewhere already, but is it possible to mimic the hue switches in Hassio?
Create the dimmer switch and tap switch buttons/actions (single ,double or hold) to enable the actions associated to them in the App?
Would be very nice indeed .
