Hue not working in 0.67
2018-04-15 00:18:12 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform hue
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 82, in async_setup
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/lib/python3.6/site-packages/homeassistant/components/light/hue.py”, line 56, in async_setup_platform
bridge = hass.data[hue.DOMAIN][discovery_info[‘host’]]
KeyError: ‘host’
My configuration is very simple
hue:
  bridges:
    - host: 192.168.1.80
To try some solutions i deleted the phue file, but when I restart the Hue configuration does not appear.
What to do?
Look under configuration panel. Hue has been moved to config entries. You can also check the config entry.yaml
I had to remove the “-” in front of host: to get things working. Others deleted the content of the deps folder.
Where? I can’t see it
I try removing the -
But documentation says to put it. Deps folder cancelling???
Edit, after removing the -
2018-04-15 14:32:55 ERROR (MainThread) [homeassistant.config] Invalid config for [hue]: expected a list for dictionary value @ data[‘hue’][‘bridges’]. Got OrderedDict([(‘host’, ‘192.168.1.80’)]). (See /config/configuration.yaml, line 334). Please check the docs at https://home-assistant.io/components/hue/
2018-04-15 14:32:55 ERROR (MainThread) [homeassistant.setup] Setup failed for hue: Invalid config.
entry.yaml?
I don’t have it
2018-04-15 14:37:21 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform hue
return fut.result()
KeyError: ‘host’
2018-04-15 14:37:21 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform maxcube
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 77, in async_setup
None, platform.setup_platform, hass, platform_config,
Sorry it’s .config_entries.json.
But from your logs its apparent that there is something wrong in how you specify your configuration from what it expects.
To go the config entry route you go through configuration -> integrations -> hue
Im getting:
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
    (self.host, self.port), self.timeout, **extra_kw)
  File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 83, in create_connection
    raise err
  File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 73, in create_connection
    sock.connect(sa)
OSError: [Errno 101] Network unreachable
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
    chunked=chunked)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 357, in _make_request
    conn.request(method, url, **httplib_request_kw)
  File "/usr/lib/python3.6/http/client.py", line 1239, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1285, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1234, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1026, in _send_output
    self.send(msg)
  File "/usr/lib/python3.6/http/client.py", line 964, in send
    self.connect()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 166, in connect
    conn = self._new_conn()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn
Any ideas?
May not be the same issue. But I solved deleting a custim_compknent related with hue
lol thats not my hue sensors CC is it?
Might be, but was long since I didn’t update it
For me the culprit indeed was your CC (I got exactly the same error as described in post #1).
My solution was to delete hue.py from custom_components and update hue.py in custom_components/sensors with the current content from your github repo
Cheers and many thanks for your great work!
