Before starting troubleshooting deeper by looking at logs suggest to first begin by optimizing your setup.
Upgrade Zigbee Coordinator firmware if possible and a newer known good firmware is available
Be sure to use a long USB extension cable for the Zigbee Coordinator to move it a bit away.
Be sure Zigbee Coordinator is on a USB 2.0 port and not a USB 3.0 port. Buy and use a powered USB 2.0 hub (which will convert from USB 3.0) if you computer does not have a USB 2.0 port.
And so on, see tips links bellow.
Regardless of the actual root cause, always aim to keep the firmware of the Zigbee Coordinator updated, add more products acting as Zigbee Routers devices and implement workarounds for interference, see:
Understand and remember that Zigbee signals are weak so rely on a strong Zigbee network mesh (meaning many Zigbee Router devices) and are very sensitive to RMF/EMI/RMI interference so it makes it much easier to troubleshoot and find the real root cause if have already optimized your setup and environment to work around that.
Thank you for this. I have been diligent on getting the mesh and the overall system set up as correctly as I am able with my skill set. This is a good reminder for me to do my due diligence with everything.
Anything new to update on this? I just migrated from OpenHAB, using the same hardware (just changed out the SD card in the Raspberry Pi), that had reliable temperature readings throughout the day. After changing to Home Assistant, the temperature readings don’t change, unless I wake the device with the button on the back.
Following up to help others, if they stumble on this.
I was able to restore full functionality of the sensor by abandoning the Zigbee integration, switching to Zigbee2MQTT, and setting up the Mosquitto broker. It’s extra work and I had to re-pair all of my devices (very tedious) but Z2M provides a lot of extra functionality and there doesn’t appear to be much added latency added by the extra overhead.
