Hello
I’m new with HA and made a simple automation that not works. Please tell me what could be the reason? T&H sensor works fine and shows the correct values, but when these values exceed these thresholds (60 and 40%) nothing happens (automation does not work) and the message does not come.
So, I have to create 2 separate triggeres? One for the upper threshold and other for the lower? It seems now I understand what the problem is ))
I believed that I indicate the range outside which the trigger should work. Now I’ll try to fix it…
Ok. And how can I cancel this temporarily set value in Developer Tools?
Now the value I temporarily set does not change (is costant), how to return the values to come again from the sensor?
Yes, now it is OK, Automation executes correctly. As I planned initially. Thanks!!!
First the simple updating of the entity (under gear) - not restarts receiving values from the sensor. Only Home Assistant Core Integration: Update entity helps - too complicate procedure )) - I’m afraid to forget this issue ))
