alkol
(ales)
October 31, 2018, 12:34pm
1
Hi, there is not an homeassistant component like “Generic Thermostat” (https://www.home-assistant.io/components/climate.generic_thermostat/ )
but for humidity?
I would like to read humidity (from tasmota mqtt dht22), setting up a treshold and when the humidity value goes below the setpoint it triggers the mqtt relay…
silvrr
October 31, 2018, 1:01pm
2
Can this not be solved with a simple automation?
Or am I missing what you are looking for?
tom_l
October 31, 2018, 1:44pm
3
Substitute your humidity sensor in the trigger of this and your relay in the action:
- id: lounge_run_dehumidifier
alias: 'Lounge Room Run Dehumidifier'
platform: numeric_state
entity_id: sensor.lounge_room_condensation_chance
above: 70
for:
minutes: 20
condition:
- condition: state
entity_id: switch.lounge_dehumidifier
state: 'off'
- service: switch.turn_on
- service: notify.ios_iphone
message: Lounge room condensing humidity alert. Dehumidifier started.
push:
sound: "DehumidifierActivated.wav"
alkol
(ales)
October 31, 2018, 2:05pm
4
Thank you @tom_l but it is nearly I was looking for.
@silvrr I would like to have something editable via UI and with HomeKit plugin.
Thank you for your answers!
Ale from Italy
