I guess this came after some HA update. How this can be fixed? The github page for the integration is at read only state.
having the same issue here, it needs to reauthenticate every day, so the integration is not really useful.
Good to hear it’s not only my problem. Uninstalled integration because it’s useless now.
Are you running the HACS one or the official one? It was moved from HACS to official HA a while back. I’ve haven’t had any reauthenticate issue in months with the official one.
Unfourtunately I can’t test this right now because my mower is being serviced.
You don’t need the mower handy to see what integration you are running. Just make sure you are not installing the one from HACS.
At integrations page it says it’s a custom integration. version 2024.1.0
I have deleted the repository from the HACS.
Install this and you should be good. Husqvarna Automower - Home Assistant
Somehow it installs always the hacs custom integration, not the official, even when repository is uninstalled from the HACS. I deleted manually Husqvarna automower folder from the custom integrations folder. I had some issues, so I recreated a new API key at developer portal. Now it seems that it’s installing the right official integration, but because the new api key, and my mower still at service, I can’t test if it’s working correctly.
