henrikrox
(Henrikrox)
1
Hi, so im trying to set a specific tempetaure, when i press, heat, cool etc on my thermostats
But i cant get it to work, any tips? I tried the code under
- id: test
alias: varmehvac
platform: device
device_id: e52ea6894947442a84af8ae8befb3465
domain: climate
entity_id: climate.termostat
type: hvac_mode_changed
condition:
- condition: device
domain: climate
type: is_hvac_mode
hvac_mode: cool
- service: climate.set_temperature
temperature: 25
hvac_mode: heat
henrikrox
(Henrikrox)
2
This works
entity_id: climate.kitchen
temperature: 24
hvac_mode: heat
But i dunno if my trigger and condition is all wrong
henrikrox
(Henrikrox)
3
from my thermostat
hvac_modes:
- auto
- 'off'
- cool
- heat
- dry
- fan_only
current_temperature: 20
min_temp: 5
max_temp: 30
target_temp_step: 0.5
temperature: 17
friendly_name: Gulvovn TV-Stue
supported_features: 1
henrikrox
(Henrikrox)
4
anyone got a tips here? think its easy, but i maybe missing something.
I just want a set temp to be set, when i set cool mode on my thermostat, and anotehr one when i use heat etc
wolfpins
(Wolfpins)
5
Maby it’s a typo but you write termostat and it is thermostat i think.
You need to manually edit the automatons file (GUI does not work).
In your trigger section add a to field and specify hvac_mode.
to: cool
to: heat
to: 'off' (need quotes)
Where do I need to put the to: part?
alias: New Automation (Duplicate)
description: ''
- platform: device
device_id: 202118665007cebf9a82e4deb486e0f6
domain: climate
entity_id: climate.1e688e13
condition:
- condition: device
domain: climate
type: is_hvac_mode
hvac_mode: heat
entity_id: climate.1e68a3ab
temperature: 21
hvac_mode: heat
to: heat
mode: single
In the trigger section.
- platform: device
domain: climate
to: heat
You don’t need the condition.
