MQTT is now included as an implementation example and data about winter peak events are better (thanks to the discussion we had with few people).
This will improve with contribution so if you’re in QC and are on Flex D or Winter Credit tarifs, share your thought / ideas.
The other aspect is the consumption information, however that is an entirely different topic as the data is delayed and is thus not compliant with HA energy (if I understood other topics correctly)
Hello, FYI recently a new feature was added to home assistant core, Local calendar.
I’m using it to enter the winter credit peak periods in it and do my automation when an event starts or ends from my “hydro-québec” calendar.
My idea was to check my email account using the “IMAP Email Content” integration and filter on hydroquebec address and parse the body to find the date and time period, it’s always either 6-9am or 4-8pm. Now we may automatically create an event to a calendar.
I did a try but currently my issue is the email body is just full of html tags and french accents are not properly decoded by default.
<li>7 f=C3=A9vrier, de 6 h à 9 h, =\r\nen matinée.</li>=0A</ul>
When I’ll be able to parse the date/dates because sometimes they send multiple periods in one email, my setup will be just fine.
I did try your addon in december but I was unsure how to use it properly, finally the calendar thing was added and uninstalled your addon because I thought it was overkill.
