HA doesn‘t detect when I am away. I have set as only tracking device my iPhone in my profile entity. HA app is installed, running in the background with “track always” enabled. My home location is set and has a radius of just 25 meters. Nevertheless, HA thinks I have been home the whole day even when I have been out. What else should I check to have a good presence tracking?
No, i checked, i had only iPhone and iPad. So I deleted the iPad from my profile. I actually thought, the little radius is better for detecting away status. Yes, I have remote access from the internet.
If your user and person were linked by having the “Allow login” option checked, then whenever the iPad logs into HA via your user it will be added back to your person’s device trackers… and you will be marked “home” if it is at home.
If you had the option checked and are using the same login on the tablet as you use on your phone, it doesn’t matter what you manually assigned to the person entity. Device trackers that you removed will continue to affect the person entity as long as they use that login and you will likely see them added back to the list automatically on restart.
Double check the person entity’s device_trackers and source attributes in the States tool when it is incorrectly “home”.
You can always test if the iPad is the source of the issue by disabling its device tracker entity for a couple days.
My partner doesn’t have any devices other than his phone. It’s the only device listed under his Person, yet HAOS constantly shows him as Home. I’ve set up zones for his workplace etc but that doesn’t seem to have any effect. Instead, even when at Work zone – HAOS shows him as Home.
Forgot to mention that my partner has an Android phone, not iPhone.
I think it may be an iOS permissions issue not allowing the HA app to continue to access location data in the background. I have a strange feeling that this started after a recent iOS update (and that permission needs to be re-granted or something like that).
Unfortunately, the iPhone with the problem is not mine and I can’t check it until next Sunday (8 days from now).
Ok, I found the solution. Actually it was a mistake from my side.
My HA app on my iPhone was connected via local address, therefore I was losing connection to HA outside of my Wifi and it was probably using my last location. Now I connected via DynDNS and everything works as expected (I even reactivated my iPad tracker wich is anyway already disconnected from my person).
